*UPDATE* Dyno tuning complete - results inside!
Old Sep 13, 2004
opto_isolator's Avatar
I have an appointment at Titan Motorsports around 12 today....I am hoping everything works out ok. I really want to start "driving" this thing! I post more info later, when I find out what happens....
Old Sep 13, 2004
C2i0v0i1C's Avatar
SuperMODrizd
o boy cant wait to see the results...holla...post the sheet to when u get back
Old Sep 13, 2004
ZdS03Civic's Avatar
ZdS03Civic is an unknown quantity at this point
Are you going to be taking any video footage?
Old Sep 13, 2004
dezod's Avatar
7thgen Power Maker
Good Luck Opto
Old Sep 13, 2004
Unfortunately I don't have a video camera - just a digital one. I plan on taking some pics tho! The guys who is going to tune it has used the emanage before, but he said he never used the additional injection feature - but its quite easy.
This weekend I played around with giving myself a rough tune - the injection feature works surprisingly well (so does the timing - I had it retarded too much, causing bogging, rough idle, and LOTS of carbon!).....But its fixed for now, until they have a chance to look at it.
Oh yeah, the wastegate.....I'm hoping this doesn't give me any issues, when it opens it makes a rather loud "rat-a-tat-tat" sound - there were a few posts on Honda Tech about other users having this issue as well, so I'm hoping its just normal......
Old Sep 13, 2004
Originally Posted by dezod
Good Luck Opto
Thanks!
Old Sep 13, 2004
Hwoody77's Avatar
Hwoody77 can only hope to improve
How much boost will you be running? Will you be posting your e-manage settings?
Old Sep 13, 2004
abmerop18's Avatar
Jam out with your clam out.
gopod luck man. cant wait to see the results
Old Sep 13, 2004
pothole's Avatar
pothole is an unknown quantity at this point
good luck with the dyno.
i had mine dynoed yesterday and it was a whopping 114.9 hp and 108 lbs/torque.
Old Sep 13, 2004
I don't want to get greedy - hopefully around 9 PSI max if everything holds together.
I'm worried about clamps blowing off, or the IAT blowing out tho....crossing my fingers that none of that happens.
As far as the settings - we'll see what happens...
Old Sep 13, 2004
dezod's Avatar
7thgen Power Maker
As far as the settings - we'll see what happens - if everything looks well I may post up some maps for the lazy people.
Opto, good luck and just an FYI ahead of time, the RSX injectors max out around 8-9 PSI.
Old Sep 13, 2004
Well guys - just got back from dyno tuning the BEAST - Darren at Titan Motorsports did an AWESOME FVCKING JOB!
The first run was a baseline run, at 5 PSI. Amazingly, with a rough tune I made 150 HP, and 150 Ft/lbs of torque.
After a lot of tuning - we cranked up the boost controller (which held rock solid where it was set - no creep what-so-ever) to around 11 PSI.
Let me just say now, the numbers that the D17 put out were simply amazing! I don't plan on running 11 PSI daily however(10 at most at the track - don't want to blow the motor / head gasket). The results?
May I have the card please:
221 HP and 207 ft/lbs of torque!
Pretty damn impressive for a torqueless wonder....
Here are the dyno charts:
Baseline
11 PSI
Maybe if the weather is nice here - I'll take it to the track on Wednesday and see what she'll do in the 1/4 mile......
BTW Dezod, I didn't have any problems with fuel at all....Maybe you should turn your FPR up a bit. Mine is set to 47 PSI at idle....
ID:	37930   Click image for larger version
Old Sep 13, 2004
RSXtypeIvtec's Avatar
Su Mo
nice results!!
Old Sep 13, 2004
HyaBoosta's Avatar
dam. All the hard work paid off in the end huh opto. I can't wait to see what mine is gonna run at 10psi. On spdrcrcks car it made 200whp and 178lb tq at 8psi.But i have some extra tricks up my sleeve to add so im hoping for some nice numbers too. what track are you going out to?
Old Sep 13, 2004
dezod's Avatar
7thgen Power Maker
Nice opto, what size turbo are you using?
Old Sep 13, 2004
StreetLevelPerformance's Avatar
Your Parts Guy
StreetLevelPerformance is on a distinguished road
Congrats Travis. It's good to know that a good e-manage tuner is only 45 mins away
Old Sep 13, 2004
dezod's Avatar
7thgen Power Maker
We have a really good E-Manage tuner in house, but a east coast renouned place in T.O. only an hour from us.
Old Sep 13, 2004
Wolfgang5884's Avatar
damn, thats freakin nice, makes me want to turbo or engine swap my car.
Old Sep 13, 2004
Bithlo - its about 15 miles east of downtown orlando...Its called Speedworld I believe.
Old Sep 13, 2004
This was on a T3 60 trim, remanufactured by garrett, obtained off of ebay. The guy advertises them as super 60's, but they aren't - they're just standard garret 60 trims (which isn't a big deal to me, because the compressor maps are fairly close).....
Old Sep 13, 2004
Yeah - he did a fantastic job. The power band was as straight as could be, I was completely amazed....
Old Sep 13, 2004
HyaBoosta's Avatar
good luck on the track im hoping to see some low 14's maybe even high 13's from you
Old Sep 13, 2004
Heh, that's if I can get the spinning under control! I peeled out in first, on my yokohama's, and they spun pretty good @ 5 PSI for a sec or two....Heh, I can't wait to see what 10 PSI will do to them!
Old Sep 13, 2004
dezod's Avatar
7thgen Power Maker
Get some BF Goodrich Drags. We can sell them to ya. Madwheel barely spins his on 9 PSI.
Old Sep 13, 2004
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
so what are u exactly running.. everything.. u know.. controller, bov.. etc...
Old Sep 13, 2004
-Hallman Pro RX MBC
-HKS SSQV BOV
-35mm Tial "replica" wastegate
-Custom manifold (SF equal length SS)
-T3-60 trim turbo
As of now, the reason the #'s are good is because I don't have a cat installed - I have a magnaflow high flow cat that I want to get installed, but need to find someone who will do it - as its illegal. Don't know how much I'll lose when I install it, but don't really want to fvck up the environment too much either.....
Old Sep 13, 2004
ZdS03Civic's Avatar
Damn those numbers are freakin impressive! Can we see some of the pics you took?
Old Sep 13, 2004
dezod's Avatar
7thgen Power Maker
-Hallman Pro RX MBC
-HKS SSQV BOV
-T3-60 trim turbo
Running a cat, plan to lose 15WHP or so. I am running a Random Tech right now. We pulled one or 2 runs with 1/2 DP & no exhaust and it felt like a beast. So, I hope that you don't lose that much. I have heard of as much as 30 HP loss as well.
Old Sep 13, 2004
RiceRocketeer's Avatar
Custom Titles are played out
RiceRocketeer has a spectacular aura aboutRiceRocketeer has a spectacular aura aboutRiceRocketeer has a spectacular aura about
Opto, don't you live in FL?
(if you do; there are no laws prohibiting you from running a catless exhaust )
Old Sep 13, 2004
I have 2 vid clips as well, from my digital camera, but they didn't turn out that great.....
