help!!!! auto to 5 spd wap I can't get it to start
Old Sep 8, 2004
bgoetz's Avatar
bgoetz is an unknown quantity at this point
I swaped an auto to a manual nad it will nto start please help!!!
Old Sep 8, 2004
zen_master's Avatar
what have you done to your car?
Old Sep 8, 2004
EviLMyStS's Avatar
All show!!!
ouch
Old Sep 8, 2004
bgoetz's Avatar
I swaped a auto to manual and it will not start it also will not give me my key back until the bat. is off. A lot of people have doen the swap, but what have they done to get it to start?
Old Sep 9, 2004
streetglower's Avatar
Doing the job correctly and hooking everything back up is the only way to get it to start. There is something you are probably overlooking and forgot to hook up. Go back over everything really carefully and see if you missed something or hooked something up wrong.
Old Sep 9, 2004
leonhsieh's Avatar
leonhsieh is an unknown quantity at this point
is your Parking light on?.....if not, then you have to go to your automatic transmission and there is a sensor you have to set it to "Park" abd then plug in the harness. For taking off the key, there is a plug where the steering column is, unplug it and you will be able to take off the key....hope this help
Old Sep 9, 2004
mugenman's Avatar
"mmmBAHHHH" - vtec y0
i heard somewhere that you had to buy and ecu for a mt car for it to work, is this true? not trying to steal the thread or anything im just wondering cause i would to like to attempt this swap
Old Sep 9, 2004
leonhsieh's Avatar
no, auto ecu works fine, but you will have CEL tho..
Old Sep 9, 2004
stl01civic's Avatar
BOOSTED DOHC i-VTEC
stl01civic is an unknown quantity at this point
nope auto ecu will work
Old Sep 9, 2004
rickinthescv's Avatar
rickinthescv will become famous soon enoughrickinthescv will become famous soon enough
First, you have to understand how an auto system works, and a manual system works.
AT has a different ECM
AT the shifter has both a starter switch and a key lock on it. When the transmission is not in neutral or park, it will not allow the starter to engage. When the transmission is not in park, it will not allow the key to be removed.
Manual has a starter engagement when the clutch is pushed in. No key lock. Reverse light is also different.
To correct the starter:
1. install pedal assembly
2. install clutch switch on assembly
3. black wire goes to ground
4. lt. green wire goes to under dash relay for the starter; this would be the gray wire from the shifter
Remove key lock wire-white/red
Also, you need the manual ECM
Old Sep 9, 2004
eklipz's Avatar
try pushing in the clutch and turning the key
Old Sep 9, 2004
Havok2k1's Avatar
Wicked Pissah Admin
Neutral safety switch hooked up?
Old Sep 9, 2004
HyaBoosta's Avatar
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
davidarenberg
May 16, 2015 08:45 AM
SSMatey
Apr 13, 2015 06:09 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
black2k1vtec
Dec 6, 2001 09:49 PM
