HKS Manifold + Wastegate = possible?
Old Sep 4, 2004
John843's Avatar
John843 is an unknown quantity at this point
Lightbulb HKS Manifold + Wastegate = possible?
Is it possible to have a wastegate flange mounted on the HKS manifold.
Old Sep 5, 2004
HyaBoosta's Avatar
HKS is a cast manifold. you would have to bore out a whole on the top and wled it in. That would weaken the manifold and be difficult due to the thickness of the manifold.I used to own one.
Old Sep 5, 2004
02fpcivic's Avatar
02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light
Nah, if its good quality casting its not a problem to do that. In time it may crack though depening on lots of variables and/or who you have put it on.
Old Sep 5, 2004
VinylPlaya04's Avatar
VinylPlaya04 will become famous soon enoughVinylPlaya04 will become famous soon enough
The downside is you can only weld steel onto cast iron using Nickle, in high heat applications. Its typically going to crack eventually anyways. Why do you want an external gate so bad?
Old Sep 5, 2004
John843's Avatar
was just wondering... thanks.
Old Sep 5, 2004
HyaBoosta's Avatar
if you want external that bad get yourself a custom manifold or a max rev.
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
SammySC
121
Apr 7, 2017 07:43 PM
jdh022764
18
Nov 3, 2015 06:44 AM
Mannimarco
Sep 7, 2015 10:01 PM
dantheman42
Sep 4, 2015 01:10 PM
