Found ARP headstuds for D17's (They fitted pics inc.)
Old Oct 7, 2004
  #31
supermex's Avatar
supermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to all
Originally Posted by robo1040
dam they are expensive!
Worth every penny.
Old Oct 7, 2004
  #32
guns's Avatar
Skyline R33
guns is an unknown quantity at this point
hey guys well i blew my head gasket so i just got done ordering the head gasket set along with the nippon leakless from majestic honda. i got the D16z headbolts from summit racing, 90.00 shipped. does anyone know the TOURQUE SPEC for the headbolts???????
Buy two h/g and stack them. Once you are running higher boost you will wish you would have. It will also lower the compression having all six layers in. I torqued mine down to 52lbs.
Old Oct 7, 2004
  #33
robo1040's Avatar
Once you go Black on Black, You Never Go Back.
robo1040 will become famous soon enough
holy christ i am furious right now, as my car sits in my driveway with the head off waiting for the head studs from summit, some idiot packaged the studs wrong!!!! when i got them from ups i was ready to put the car back together, only to find when i opened the box there was studs in there that were to big!! the outside of the box is labled with the part number, 208-4301 HONDA D-16 10mm HSK (which is the right stuff) but inside, i found 10 7/16 studs that wont fit into my head! im guess someone at ARP labeled the outside of the box wrong
Old Oct 7, 2004
  #34
robo1040's Avatar
i bitched summit out and they are sending me a new box of studs, and i told them i needed them today so they are sending them overnight for free! hha you can get anything you want if you bitch
Old Oct 7, 2004
  #35
guns's Avatar
Skyline R33
Did you tell them to send an extra headgasket. You will need it and you can run a little extra boost with the lowered compression.
Old Oct 7, 2004
  #36
robo1040's Avatar
hahaha, your all about the extra head gasket thing. i didnt get the gasket from summit, i got it from majestic honda. anyhow, i still cant believe that your running 2 gaskets??? do you really think ill blow out the one leakless at like 9psi?
Old Oct 7, 2004
  #37
guns's Avatar
Skyline R33
at 9psi no. But one night at the track you will be beat by a modded SRT-4 and you will want to turn the boost to 12psi. It will pop. I should have done this from the start.
Old Oct 10, 2004
  #38
sspem2's Avatar
em2
http://www.wiredspeed.com/itemdesc.a...2D4301&eq=&Tp=
89.00 bucks here. im gonna get them and put them on my head.
GolNat
Suspension DIY
May 12, 2022 06:49 AM
FurBall
Jun 10, 2015 03:13 PM
jordan1794
Jun 8, 2015 04:03 AM
tattedlariat
Apr 17, 2015 03:26 AM
ImmortalEX
Nov 8, 2001 09:52 PM
