SF kit boost controller install
Old Aug 23, 2004
dragoon's Avatar
To install a boost controller (MBC, in my case) on the internal wastegate setup, do I tee off that vacuum line connecting the wastegate to the housing, and run that to a vacuum source? Which side of the boost controller points to the actuator? And where is the closest vacuum source to that thing? The throttle body one is kinda far...
Old Aug 24, 2004
guns's Avatar
Skyline R33
guns is an unknown quantity at this point
My MBC is a bleeder valve spliced into the little hose from the turbo to the actuator housing. It does not go to any vacum source. The more you open the valve the more boost you get. You just open a little boost check the gauge and keep doing that in small steps until you are happy. I actually have a $2 fish tank valve from Petco.
Old Aug 24, 2004
MadWheel's Avatar
Premium Boosted Member
yeah basially tee into the one hose that runs from the turbo housing to the wastegate. it's the same setup for electronic boost controllers too...
Old Aug 24, 2004
civic01vtec's Avatar
^^^ what he said
Maaachoooo
Turbo
Aug 27, 2015 01:49 AM
Supramk3
Jun 11, 2015 11:13 AM
Supramk3
May 11, 2015 07:55 PM
Dorval Andre
Electrical
May 6, 2015 02:33 PM
