Got my RSX-S injectors and fuel rail today
Old Aug 26, 2004
  #31
abmerop18's Avatar
Jam out with your clam out.
nice drawing
thanks.
so ill just go to home deopt and get a screw identical to the one you sent me
Old Aug 28, 2004
  #32
canadian2k1si's Avatar
canadian2k1si is on a distinguished road
I used a Metric (I am Canadian!) bolt 30mm, M6x10, and 2 washers because the RSX injectors are about 0.75In longer that the Stock Civic ones.
http://www.7thgencivic.com/forums/sh...53#post2242853
Old Nov 11, 2004
  #33
Crackhead79's Avatar
well I know this has been discussed, but I wanted to hear from you all here, if I stayed with the returnless system I can use the stock RSX injectors, but if I go to RETURN fuel system, can I still use these or do I have to convert to OBDI plugs and use RC injectors? thanks guys...good work canadian!
Old Nov 11, 2004
  #34
abmerop18's Avatar
yeah, you can still use the rsx injectors with a return system
Old Nov 15, 2004
  #35
bradmanuwf's Avatar
bradmanuwf will become famous soon enough
you can use your stock fuel rail from the civic. you just need longer bolts and some washers to take up the space cause those injectors are longer. I just won some DC5 K20a Type R injectors on ebay for $35 coming straight from japan. I'm just going to find some bolts that fit and use washers to take up the space for a proper fit. they are suppose to fit pretty tight in the fuel rail cause of the fuel pressure....don't want any leaks. I've been told that you can put an inline booster pump for added pressure no problem, but I haven't tried it or seen it in person so don't quote me.
Old Nov 15, 2004
  #36
HyaBoosta's Avatar
so any answers yet on the exact bolt and spacers needed? Has anyone checked to see if the type R injectors have a better flow rate then the type s? and if they clips are the same?
Old Nov 15, 2004
  #37
bradmanuwf's Avatar
I'll let you know after I get them. they're coming from tokyo, so it will be a little while. I'll do a DIY when I put them in, and let everybody know which bolts and how much space needs to be taken up. but like I said, it will be a little while. cause of shipping, college/school work, and job work.
Old Nov 15, 2004
  #38
HyaBoosta's Avatar
yea keep us posted. I really want to know if they are plug and play.
Old Nov 22, 2004
  #39
bradmanuwf's Avatar
I got my injectors Sat. but I don't have any time to put them in for a while. I'll let you guys know when they're installed, and put up a DIY. I'll be putting on my turbo this weekend too if I get the downpipe adjusted and the oil pan back by Sat.
ZeroDegreze
Jun 17, 2015 11:10 PM
Diznavis
Jan 6, 2002 09:13 PM
Cross
Dec 30, 2001 09:27 PM
Red2k1ex
Dec 5, 2001 09:34 PM
MooCoW
Nov 15, 2001 10:58 AM
