Mystery parts....
Old Aug 19, 2004
cosmo's Avatar
cosmo is an unknown quantity at this point
Mystery parts....
What is some of this stuff? There's 2 steel braided lines with ends and the one larger braded lines with no ends. Whats some of this other stuff? The black box says something about the MAP, other then that I don't know where most of these fittings go... Any help is appriciated.
Old Aug 19, 2004
opto_isolator's Avatar
Large braided hose for oil return, small braided hose is for oil sending line. Black rubber hose is for running vacuum hose. The one with the three white things on looks like a MAP sensor isolator (check valves) - similar to missing link....
Old Aug 19, 2004
Titleist71's Avatar
isnt the white thing with the three prongs, 5 altogether, for all the vacuum lines?
Old Aug 19, 2004
SODJAZERO's Avatar
SODJAZERO is an unknown quantity at this point
^^^ The white plastic thing is a boost/vac manifold so to speak. You connect your vac hoses from your wg, bov, boost gauge ect... to that little plasti thing.
Old Aug 19, 2004
Oops yeah, its a vacuum manifold - a cheap one it looks like too....
Old Aug 19, 2004
cosmo's Avatar
Thanks, whats the second steel braided line for? There's 2 that are the same size.
mjdiaz89
Jun 21, 2016 09:26 PM
7thgensurvivor
Jul 27, 2015 08:23 PM
LiKEaFeRiO
Jun 3, 2004 02:15 AM
Nuts
Bolt-on Engine Performance
24
Sep 25, 2002 07:25 AM
