oil return line kit on a EX
Old Aug 5, 2004
Titleist71's Avatar
Ok....I've been serching and contacting people for a oil return line kit for a T3. I have found little results on the net and i get answering machines . Ok...I need to know what u guys did. The people with Ex's, did you get a aluminum fitting for the oil pan? Does the kit from fast-turbo.com come with a aluminum fitting or bung? i get such scattered answeres and I need a clear consise answer on this to help me get this one last piece.....well I also need the sizes of silicone couplers for a SF kit.....replacing the SF couplers with silicone and I need the total # of couplers and correct sizes....I have been searching for that and haven't come up with anything immediately. Thanks for the help...links or pics or anything related directly would be great!
Old Aug 5, 2004
civic01vtec's Avatar
i upgraded my couplers to silicone
You will need........
(1) 2.0"
(2) 2.5"
(1) reducer coupler .....2.5" to 2.25"
and the rest in 2.25 inch, i forget how many......i just ordered extra. I will check later for u though.
Old Aug 5, 2004
Titleist71's Avatar
you are a . This helps with my ordering. Oh ya I also have to give mad props (tossin up gang signs right now...lol.) to Mr. Dobson for the turbo kit and all the great business...he is an awsome guy to work with. If anyone has info on that oil return line kit too that would be outstanding.
Old Aug 5, 2004
2k2redcivic's Avatar
2k2redcivic has a spectacular aura about2k2redcivic has a spectacular aura about
i just tapped the front of the oil pan high up and threaded in the fitting. than i jb welded it in never leaked and works great. carefull not to over tighten
Old Aug 5, 2004
ok, you will need (6) 2.25" couplers....maybe get a extra one just in case.
i got them from here.........the cheapest place i have found
http://www.atpturbo.com/Merchant2/me...egory_Code=SIL
Old Aug 5, 2004
oh, also.........make sure u get T bolt clamps.......2 for each coupler
here is the cheapest place to get them........where i got mine
http://www.partssystems.com/shop/pro...egory_id=TBOLT
Old Aug 5, 2004
hmm.......how bout this fitting.
http://www.atpturbo.com/Merchant2/me...egory_Code=OIL
Just buy a npt tap and drill your pan. Put thread sealer on the threads and put some JB weld around it.
Also, this return hose would work great with that fitting, it is resistant against high temps.
Old Aug 5, 2004
Or, you can get really elaborate and spend the big bucks
then.....
then....
then......
That is about $70 plus shipping......but would be one hell of a sweet set-up
Old Aug 6, 2004
Titleist71's Avatar
i'm gonna go with the set-up in your last post ^^^ I like that best and it will last the longest...not worried about money. Thanks for all the help! Now I have everything, and I will be finished by the last week of august, installed and running...I hope.
RIPSAW
Nov 6, 2015 04:36 AM
Black91civic
Jun 6, 2015 08:15 AM
zaboomafoozarg
May 30, 2015 09:21 AM
elitezdc5
May 26, 2015 05:46 PM
supercivic01
South
Nov 30, 2001 11:27 AM
