turbo boost
Old Aug 2, 2004
d17lpower03's Avatar
d17lpower03 is an unknown quantity at this point
turbo boost
wassup fellas...i was wondering if yall know where i can get some fuel injectors that can handle 7 psi for our 03 civic ex coupes??? thanks alot =P
Old Aug 2, 2004
taz757's Avatar
RSX injectors.
SLP is coming out with a return fuel kit. Check that out when it comes out.
Old Aug 2, 2004
civic01vtec's Avatar
stock
RSX
VW 1.8
Old Aug 2, 2004
jwcardy's Avatar
SRT-4 owner with 2MCHPSI
jwcardy is on a distinguished road
Originally Posted by taz757
RSX injectors.
the return fuel kit WILL NOT be offered right away with injectors...maybe that will be an option in the future.....
Old Aug 2, 2004
taz757's Avatar
Yeah. I should have made that clear.
The fuel rail is supposed to be modified so that it'll take RSX injectors, right?
Old Aug 2, 2004
you will need longer bolts and spacers
Old Aug 2, 2004
2k2redcivic's Avatar
2k2redcivic has a spectacular aura about2k2redcivic has a spectacular aura about
u already have injectors capable of 7 psi
i run 8 on them
Old Aug 2, 2004
gotti's Avatar
i run 8 on them
how the hell do you do that when my car wouldnt even hit boost with the normal amount of fuel?
Old Aug 2, 2004
so wut do u all suggest i do???...becuase im runnin 7 psi...and i only can hit up to 5000rpm..and there is alot of smoke coming ou to f my exhaust...is that normal???...
is a FMU same as FMS???
would i need anythign else??..casue this is a custon turbo...the turbo is off of a 00 civic ex...
pleae help =D =D =D
Old Aug 2, 2004
gotti's Avatar
dude, get some fuel management. you're gonna f*ck something up.
Old Aug 2, 2004
REDchirp's Avatar
REDchirp should not be trustedREDchirp should not be trusted
he's prob running a larger turbo at 7psi... where as most of ours are smaller running at 7-8 PSI and it's not a prob... there is a huge diff. if his turbo is larger to begin with.... he might blow something real fast...and i'm waitin to see how long till he posts that his motor blew up
Old Aug 3, 2004
so u suggest a fuel managementunit or system???
Old Aug 3, 2004
of course........u can't add air without fuel
Some ppl argue that our obd II's will supply enough fuel up to 5 psi.
Old Aug 3, 2004
jwcardy's Avatar
we never said anything about the rsx injectors...the return fuel conversion just converts the 7thgens fuel setup from that of a returnless style to a return style...like that of previous generation civics....now, opto has successfully installed rsx injectors on his factory fuel rail, so it can be done...but dont hold me to that...i believe that all you need is longer bolts to hold the fuel rail inplace because the injectors are longer...
Old Aug 4, 2004
SpdRcrChk's Avatar
BOOST JUNKY
SpdRcrChk is an unknown quantity at this point
Yuppers. RSX injectors will drop right in. Good luck finding them though. Hopefully enough RSX'ers out there have upgraded and we can start seeing more of them.
Old Aug 5, 2004
ok then...so our stock injectors will handle 9 psi rite?....and all ill need is a msd inline pump and a FMU...correct???.. =D =D...sorry i ask..cause im getting people givign me no or yes to my stock injectors...thank you =D =D
Old Aug 5, 2004
99% of us boosted 7thgens are using stock injectors
Old Aug 5, 2004
familycar's Avatar
http://www.7thgencivic.com/forums/sh...2&page=1&pp=15
sale on gredy emanage this is what you need. or atleast something of this sort like a safc which is less intensive.
Old Aug 8, 2004
u can use the same set up i have. aeromotive fmu and return line conversion, def the safest and best. or go with alchohol injection.
bowie
Jan 21, 2018 09:29 PM
HondaGuy7
Feb 22, 2016 01:00 PM
C-Hamm
Sep 28, 2015 10:31 PM
Michelle2006
Sep 19, 2015 06:09 AM
99BoostedSi
Sep 7, 2015 04:49 PM
