Another install question....
Old Aug 2, 2004
CivicMexicano's Avatar
El Pinche Turbo Mexicano
CivicMexicano is an unknown quantity at this point
Well i've been serching like a bitch and hAVE not been able to fint out how to conect the Alcohol injection switch, ones goes to ground and the other one where does it go??
Also my fuse box does not have one of the screws painted red, and a friend told me that both were the same is this true??
Old Aug 2, 2004
StreetLevelPerformance's Avatar
Your Parts Guy
StreetLevelPerformance is on a distinguished road
It's a switch so when closed it sends power to your windshield wiper pump. Connect it to a power supply.
Old Aug 2, 2004
ImportRacer2123's Avatar
K20 Member
Power Supply as in a toggle switch?
Old Aug 2, 2004
Your Parts Guy
The pressure sensor that you install in the pipe is a switch. When activated it sends power to the windshield washer pump. When not activated you aren't spraying alcohol.
Old Aug 2, 2004
K20 Member
oh wow its a built in toggle switch
Old Aug 2, 2004
I know wat it is what i wanted to know is to what wire from the windshield washer pump is it conected to..........
Old Aug 3, 2004
Jeff's Avatar
Jeff is an unknown quantity at this point
send a pm to madwheel, or civic01vtec. Either one should answer your questions for you.
Old Aug 3, 2004
player1002's Avatar
player1002 is an unknown quantity at this point
It shouldn't matter. The pressure switch just makes and breaks the connection. As long as one goes to a constant power and the other goes to the pump wire it will work. To check turn the car acc on and use a jumper wire to go from terminal to terminal. If you hear the pump go on it's working alright.
Old Aug 3, 2004
civic01vtec's Avatar
I connected one wire to the blue/white wire on the pump and the other to a 12volt switch power......which i used the green/yellow wire in my cig lighter. This is also the same wire that i used to power the inline pump in my FMU.....i got rid of the relay.
Old Aug 3, 2004
yes, do this to make sure it works and to adjust the pressure sensor you will need a allen wrench. I hooked the hose up to my windshield washer pisser, went for a drive and saw what psi is sprayed at and went from there. To lower the psi setting, turn the screw to the left. To raise the psi setting, turn it to the right.
mjdiaz89
Jun 21, 2016 09:26 PM
OptimisticWay
46
Oct 15, 2015 02:16 PM
mrwhos
Aug 11, 2015 02:03 AM
17
Jul 23, 2015 11:48 PM
EM_WON
Jul 22, 2015 06:49 PM
