Alcohol Q.....
Old Jul 27, 2004
CivicMexicano's Avatar
El Pinche Turbo Mexicano
CivicMexicano is an unknown quantity at this point
Alcohol Q.....
I'm about to inish my tubo intall, but i was wondering, what was the best combination of water-alcohol, also what kind of alcohol would be the be to use, i can't get Methanol here (live n' Mexico), so what other type of alcohol could i use......
Old Jul 27, 2004
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
hey man
isopropyl aka rubbing alcohol works fine. You can also go with denatured alcohol. I heard 70/30 works best with rubbing
please do not run over 8 psi ... I blew my headgasket twice because my boost controller had trouble learning my boost (due to a bad clutch). my friend also blew his trying to run 12 psi... he fixed it, but now he's not going over 7. also be careful when u floor it for the first time to make sure u don't overboost
Old Jul 27, 2004
thanks........
Old Jul 27, 2004
civic01vtec's Avatar
isopropyl with distilled water....50/50
Old Jul 27, 2004
MadWheel's Avatar
Premium Boosted Member
or methanol with distilled water... 50/50...
Old Jul 27, 2004
guns's Avatar
Skyline R33
guns is an unknown quantity at this point
Meth only. I have a 231 dyno as proof. With alch and water 50% mix I only made 186 at the same boost. I was a little lean and the meth seemed to add fuel it needed.
Old Jul 28, 2004
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
^^ very interesting info
Old Jul 28, 2004
Civic Type S's Avatar
Civic Type S is an unknown quantity at this point
guns are you trying to pull our legs about that dyno stuff, does it really make that much of a difference?
Old Jul 28, 2004
Jaykuai's Avatar
ish...
CivicMexicano,
Methanol is easy to find and buy here, i can get you an entire tanker if you like
Old Jul 28, 2004
ImportRacer2123's Avatar
K20 Member
PEople said straight methanol... why do you say 50/50?
Old Jul 28, 2004
guns's Avatar
Skyline R33
For me it did because at 10-11psi I was lean. The extra fuel from the meth made it run alot better.
Here is the before pic with alch and water. See the difference...
Old Jul 28, 2004
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
YOU HAVE ALTEZZAS!! YOU'RE GAY!!!
haha jk
Old Jul 29, 2004
MadWheel's Avatar
According to what I read, straight methanol actually increases temps, even though it increases octane rationg and fuel. If you do 50/50, the car will be slightly cooler, which will help resist detonation, even though there's less fuel going into the engine. A simple fuel computer, richening up the mixture would be best as well. I have my emanage set to +5% fuel until it get's properly tuned.
Old Jul 29, 2004
K20 Member
So will the SF System work fine? for now?
Old Jul 29, 2004
guns's Avatar
Skyline R33
Have you checked the octane rating for pure methanol? It is very high around 145 which reduces detonation and burns cooler. But I could be wrong. I learn through trial and error.
Old Jul 29, 2004
guns's Avatar
Skyline R33
haha jk
NO altezza here. Just DIY blackout rears.
gearbox
Lighting
467
Oct 16, 2017 02:03 PM
iamboo
Engine Swaps
36
Mar 4, 2004 04:05 PM
CivicRacer5
Engine Swaps
Oct 29, 2003 06:02 PM
opto_isolator
Engine Swaps
Aug 7, 2003 08:40 PM
