Can someone clear this up: fuel for turbo apps
Everyone is always talking about different setups for getting enough fuel in the engine..
Im just trying to understand whats good and whats not.
Whats bad about the SF system? What IS the SF system
How about SLP's return kit...i know this will be expensive...
What other routes are there.......Are they safe? compared to a return line system.
Are people trying to boost higher with more sophisticated fuel setups? Or just run safer.
How about those rsx injectors, how much better are they than stock.
When dezod releases his T-kit I may have the money for it.
Id only want to boost up to say 8psi...
1. Theres nothing bad about the SF kit but it's only good till about 9-10 psi and It's an Inline fuel pump. it puts alot of pressure on the injectors cause theres only so much fuel the fmu can pump with the stock pump in the tank and small injectors.
2.SLP looks solid and the larger fuel pump and fuel pressure reg. are gonna be alot safer. also modded rails for bigger injectors.(RSX)
3. I think our injectors are 220cc and rsx-s are 330cc(maybe wrong)
I just test fitted them until I can get the rest of my stuff from SF - I have an emanage to adjust the fuel, but when you play with the MAP sensor, the timing also needs to be adjusted because it is mostly based off of the MAP sensor (as well as the IAT sensor).
Civic15
18
Sep 19, 2017 07:48 PM
Touge
Ottawa
Jul 18, 2015 05:39 PM
Touge
Jul 18, 2015 05:35 PM
LorenzoC0395
Jul 14, 2015 08:46 PM
