dude is my motor going to blow?
Old Jul 21, 2004
03CivicEX03's Avatar
03CivicEX03 should not be trusted03CivicEX03 should not be trusted
I just brought my car to the shop near my neighbor hood and they are installing my turbo for me. I swear the owner keep on saying my motor is going blow few timeS! "your motor is going blow" your motor is going blow". I like yeah there hella people running turbo on stock motor but they are not running high boost. dude crazy *** owner . Yeah i'm running on sf turbo kit with the sf fuel system.. i have 2 injectors in charge pipe, control by erl mf2. How long did you guy been running turbo on your car and any problem with it?
Old Jul 21, 2004
jwcardy's Avatar
SRT-4 owner with 2MCHPSI
jwcardy is on a distinguished road
when i had my sf kit i was running 8lbs with their fuel setup...why are you using their fuel setup and the 2 extra injectors...sf setup is fine for now....
if you are careful and take care of your car, then you will be okay
Old Jul 21, 2004
^^ nah i'm not using there fuel system.. i brought the kit used soo... it come like that
Old Jul 21, 2004
Havok2k1's Avatar
Wicked Pissah Admin
Well which is it? The SF fuel system or the mf2? You shouldn't run both....
Old Jul 22, 2004
the kit don't come witht he sf fuel system. I'm using mf2 with 2 injectors in charge pipe.
Old Jul 22, 2004
JetBlu01's Avatar
New Member
JetBlu01 is an unknown quantity at this point
this sounds like Sam's old kit...
Old Jul 22, 2004
ImportRacer2123's Avatar
K20 Member
it is his old kit
Old Jul 22, 2004
SODJAZERO's Avatar
SODJAZERO is an unknown quantity at this point
You will be ok man, just make sure its tuned rite. Mine has been installed since last valentines day, ive had no problem.
Old Jul 22, 2004
REDCivicEX's Avatar
REDCivicEX is an unknown quantity at this point
About how much was it to have installed?
Old Jul 22, 2004
500 bill! turbo kit,Turbo timer,boost control.
Old Jul 25, 2004
bakablo's Avatar
bakablo is an unknown quantity at this point
i ran my car with 6.5 pounds of boost with only rsx type S injectors... works fine.. or did.. until it ried installing a vafc and blew my ecu...
but that was my fault
Old Jul 25, 2004
krayziebonet4l's Avatar
Samoan<^>(-_-)<^>Power
krayziebonet4l is an unknown quantity at this point
^^^You can run 6.5 lbs of boost with only rsx-s injectors? if so thats tight...
Old Jul 25, 2004
bakablo's Avatar
shifting at 4 rpm... yes...
Old Jul 25, 2004
Speedracer32's Avatar
Speedracer32 is an unknown quantity at this point
loo..i take it a little futher now
only thing is if you take it too far the ecu see boost or you run too lean and puts your car in limp mode. some time it just shuts it off. Then you stop and restart it. As long as you dont go full throttle you should be O.K. that's what mine has been doing. A coupple ocassions i pushed it too much instead of letting it ease into boost and it pulls it self from then on
SAFC w/ RSx injectors
I did it the first on the way to the mid atlantic meet and i didn't know what the **** happened. Put 2 and 2 together and makes sense to me. ( my personal expericence)
juror
Suspension DIY
Jul 30, 2019 03:28 AM
cizsak
Jul 21, 2015 03:39 PM
liagreenhalgh92
Jul 21, 2015 01:31 PM
Civic65
Jul 19, 2015 10:13 AM
ZILLA
Air Conditioning
Jul 11, 2015 08:35 PM
