H-E-L-P---Missing Link Installation
Old Jul 16, 2004
pnoyster2k1cvic's Avatar
Balut Eating Champ
Question H-E-L-P---Missing Link Installation
hey you guys, I got a turbo newbie question...
i've been searching online and haven't found a missing link diy... I'm getting my SF turbo kit soon and I was wondering if it is necessary to have a missing link? and can you guys tell me how, and where to install this missing link?
any info will be greatly appreciated... thanks!
Old Jul 17, 2004
Speedracer32's Avatar
Speedracer32 is an unknown quantity at this point
it goes between your map sensor and the intake manifold
kinda like the cream between two oreo's
Old Jul 17, 2004
http://www.beesandgoats.com/boostfaq...tml#Management
Old Jul 17, 2004
Balut Eating Champ
^^^yeah I already seen and read that... but where and how to install on the engine... anybody?
Old Jul 17, 2004
civic01vtec's Avatar
piece of cake........takes 2 min.
Next to your TB on the drivers side is your stock map sensor. It will say....Denso sensor map.......it is black. There is a philips head screw holding it in. Unscrew it and pull up the map sensor.......take the ML and put the Map sensor on top of it and screw it back down with the supplied hardware.
Old Jul 17, 2004
zinkyroo's Avatar
cool beans
zinkyroo is an unknown quantity at this point
make sure the the o-ring on the missing link seals when you put it in your throttle body.
Old Jul 17, 2004
^^^^ yeah, also make sure that u install the filter with it and you clean it on a regular basis or ur car will flutter and run like ****.
Old Jul 17, 2004
btw.............wtf is "balut" ?!?!?!?
Old Jul 17, 2004
Drivetofast's Avatar
Supercharged k20a3
Drivetofast is an unknown quantity at this point
it is really easy as long as you don't strip the screw, you don't need it though, i have been runnign 7-8 psi for a long time and have had no problem. the only problem i had was when i ran 12psi without it and the car went into limp mode.
Old Jul 17, 2004
Balut Eating Champ
^^^ thanks... yeah I was just planning to run it at 8psi, and maybe 10 on dyno... just to see the numbers... thanks drivetofast great info!
balut is a delicacy in the philippines... it's a developed duck eggs... for more info click here>>> BALUT hmmmmm yuummmmmyyyyy!
Misfit2613
Jul 30, 2015 09:49 AM
fordover
Jul 11, 2015 09:10 PM
Bill in San Jos
Jul 10, 2015 12:32 PM
fvckbg
Jul 7, 2015 07:08 PM
robbie374
Jul 7, 2015 02:56 AM
