Inline fuel pump burned up again
Old Jul 13, 2004
civic01vtec's Avatar
Angry Inline fuel pump burned up again
Well, about 3-4 wks ago, the inline fuel pump in my vortech FMU burned up. So i ordered a MSD inline from www.streetlevelperformance.com and tonite i noticed that my a/f gauge showed me running lean and i got home and i couldn't hear my pump running at all. There is a slight possibility that maybe it is wiring, but i will check it out tomorrow. But i am betting that the pump burned up again.
Both pumps have a max rating of 125psi..........i am running 9psi, so that it is 90psi plus whatever stock is. Could i be overloading the pump ???
Is anybody else running more than 9psi with SF's fuel system, i know a few are
Old Jul 13, 2004
Big Baller L's Avatar
Nugget Garage Since 2004
^dayum that sucks man. There must be something wrong, cuz two pumps burning out seems too much for a coincidence. If i could post any legitimate reasons why then i would, but id be making stuff up. I just hope you figure it out soon. Good luck man
Old Jul 14, 2004
MadWheel's Avatar
Premium Boosted Member
I think you have bad luck or something's pinched. Do you ever have the pump running with the engine off? That supposedly burns up the pump very quickly so avoid doing that.
On another note, the pumps SF ships with their kits support up to 600 hp so, if installed properly, you're not straining it.
Old Jul 14, 2004
i was actually wondering about that b4...............and now that u mention it, my friends were watching a DVD in my car for about 20 min last wk.
Old Jul 14, 2004
ImportRacer2123's Avatar
K20 Member
Doh!
Old Jul 14, 2004
Speedracer32's Avatar
Speedracer32 is an unknown quantity at this point
the fuel pump keeps running while the engine is off??/
how is that?
Old Jul 14, 2004
how is that?
it is wired to a constant power........when u turn the key on, the pump runs, but no fuel is going through it.
Old Jul 14, 2004
is that the right way to wire it??
there isn't a way to wire it so when the accelerator is pressed/depressed that is shuts on/off?
Or a way for it to kick in at a certain RPM?
like how nitrious kits do?
Old Jul 14, 2004
Jeff's Avatar
Jeff is an unknown quantity at this point
Yeah anyone know a different way?
Old Jul 14, 2004
yeah, that is the right way
i might just put a toggle switch on it.
Old Jul 14, 2004
MadWheel's Avatar
Well... If it's wired right, it only comes on when your key is in the "run (II)" position. If you keep the key in the "Acc (I)" position, only your radio is on, and the pump stays off.
Avoid putting your key in the II position while the engine is off, the more you do so, the longer your pump will last.
Old Jul 15, 2004
Civic Type S's Avatar
Civic Type S is an unknown quantity at this point
what madwheel said is correct, that is how I have mine
Old Jul 15, 2004
Jeff's Avatar
Makes since, Which constent power source did you guys hook yours up to. Sf says to find the power off of the fuse box under the hood, is this the correct way?
Old Jul 15, 2004
MadWheel's Avatar
That's the constant for the relay that SF is supposed to send with the kit. The blue wire goes to your ingition key (black with yellow stripe i think...)... then you ground the gnd terminal on the relay.
When you turn the key, it sends power to the relay, opening an electronic switch, which then sucks power from the constant (red wire).
CarStuff
Dec 6, 2020 12:52 PM
mrcell24
May 19, 2015 10:02 AM
JoeB16
61
Oct 16, 2003 07:58 PM
htowncivicEX
Jan 21, 2002 11:48 AM
