Alcohol Injection Question?
Old Jul 12, 2004
ImportRacer2123's Avatar
K20 Member
Hey My buddy and I were discussing Alcohol Injection.... he was saying that the tank MUST be DOT approved... is this true? If so is the tank that comes with the Alcohol Injection DOT approved? If not where can I get one? someone link some sites where to buy some.
Old Jul 12, 2004
JetBlu01's Avatar
New Member
JetBlu01 is an unknown quantity at this point
alot of us are using our windshield washer fluid tank...all I did was take it aloose rinse it out good and put some alcohol in there....tell your friend to go DOT HIS *** lol
Old Jul 12, 2004
K20 Member
OK so i should be fine to run at the drags?
Old Jul 12, 2004
K20 Member
Can you buy Methanol and not get hasseled? I mean not sure if they will let me buy it.. anyone have any problems getting it?
Old Jul 12, 2004
pnoyster2k1cvic's Avatar
Balut Eating Champ
^^^i'm gettin my turbo kit soon and wanted to run an alcohol injected boost...
where can we get the pump or the sprayer whatever it is to have an alcohol injection, and any DIY?... please help a noob out! thanks!
Old Jul 12, 2004
dezod's Avatar
7thgen Power Maker
I sell a Turbonetics Alchy/H20 Spray kit.
Old Jul 12, 2004
Balut Eating Champ
^^^can you provide with a link, I can't find the damn thing... and how much for the kit?
Old Jul 12, 2004
civic01vtec's Avatar
it doesn't need to be DOT appoved...........i've never seen a track inspect your car in open drags.
Old Jul 12, 2004
Balut Eating Champ
your oem windshield washer reservoir is DOT approved! BAM!!! you're set!
Old Jul 12, 2004
yeah, i was actually thinking that too
Old Jul 13, 2004
dezod's Avatar
7thgen Power Maker
The Turbonetics one is $239.
Old Jul 13, 2004
HyaBoosta's Avatar
dezod can you post a link to what it looks like?
Old Jul 13, 2004
dezod's Avatar
7thgen Power Maker
Let me see what I can do:
Note...This system is for TURBOCHARGED and SUPERCHARGED Engines ONLY !
"The system uses a pressurized aluminum tank to keep the water and intake manifold at the same pressure so that a high pressure pump is not needed. Boost pressure from the intake manifold pressurizes the tank. This keeps the cost down and delivers very reliable performance.
A tank of water (or water / alcohol mix.) on average will last 1 tank of gas. If you are running very high boost levels and/or driving the vehicle exceptionally hard all the time then the water consumption will be higher. Excellent as an addition to your intercooler for running higher boost levels in warm weather and MUST for non-intercooled systems. System is adjsutable for starting point via an adjustable pressure switch."
Water Tank Dimension for #980 Kit: 9.625" x 5" x 2.5"
Old Jul 13, 2004
Balut Eating Champ
be cool pump and acc only at 200 I think I'll get that and use my Winshield Reservoir... the one you got up there looks pretty small...
Old Jul 13, 2004
HyaBoosta's Avatar
how much is the SF alchy sprayer?>
Old Jul 13, 2004
K20 Member
Umm the SF one is I think is $100 I bought my from StreetLevelPerformance (Dober) for cheap never used and coming with instructions.
Old Jul 13, 2004
Balut Eating Champ
100bones is more reasonable... 239
Old Jul 14, 2004
MadWheel's Avatar
Premium Boosted Member
So 100 for a very cheap 2 peices? VS 239 for an actual kit?
The SF kit is a sprayer (with somewhat of a rough atomization) and a Holley brand pressure switch. You can buy both parts for about 70 online.
The kit dezod sells is an actual kit, not two parts.
tuvok
Sep 25, 2015 03:13 PM
herbiej
22
Aug 23, 2015 01:02 PM
RIPSAW
Aug 16, 2015 12:14 PM
martinsmartin
Aug 15, 2015 07:34 PM
15EXCoupe
Jul 30, 2015 12:59 PM
