SF fuel system HELP!
Old Jul 1, 2004
gotti's Avatar
I attached a picture....
Is that hole supposed to be there and what goes into that plug? Thanks
Old Jul 1, 2004
ImportRacer2123's Avatar
K20 Member
Gotti i couldn't help you out mine came with hella missing parts..
Old Jul 1, 2004
hans's Avatar
hans is an unknown quantity at this point
I hope you bought that and you knew it was used....cuz if thats "new"....
Old Jul 1, 2004
taz757's Avatar
Yeah. Is this out of a used kit or a new kit? If it's new, I'd go ape over it. I thought that SF was supposed to be using all brand new parts?
Old Jul 1, 2004
gotti's Avatar
Thats a used kit. Is something supposed to be therE?
Old Jul 1, 2004
fuchs's Avatar
fuchs is an unknown quantity at this point
That **** looks totally different from mine. I know the plug is your relay for the fuel pump. You should have a power, ground, a wire to the pump, and one to the ignition. I don't know about that hole though.
Old Jul 1, 2004
Drk01Civic's Avatar
Drk01Civic is an unknown quantity at this point
Maybe whoever you bought it from had a fuel pressure gauge there? I don't know.
Old Jul 1, 2004
gotti's Avatar
^Yeah that sounds right. I think he did have a fuel pressure regulator... Hmmm, so what would I do then, just get a bolt that would fit that area? I dont plan on getting a fuel pressure regulator, so that area will spew out fuel unless I fill it in.
Also, my pump doesnt have a ground...where does that come out of? Mine has a red and green wire only
Old Jul 2, 2004
Hatorade's Avatar
SPLAT!!!
Hatorade is an unknown quantity at this point
the green wire
look at the connections ones positive -red wire and ones negative -green wire.
dude i hope YOUR not installing this by yourself.
Old Jul 2, 2004
civic01vtec's Avatar
on the fuel pump itself, there is a positve and negative side. The symbols are hard to see. You can just hardwire the pump without using the relay.
vtecbrah
May 31, 2015 01:24 PM
PJ
Sep 5, 2003 01:00 PM
PJ
Jan 27, 2002 03:53 PM
htowncivicEX
Jan 21, 2002 11:48 AM
TaiChi
Dec 17, 2001 09:09 PM
