* New Question*
Old Jun 29, 2004
REDchirp's Avatar
REDchirp should not be trustedREDchirp should not be trusted
Unhappy * New Question*
I'm buying piping from this girl that has paint her IC piping with a High temp 1200 degree resistant paint on the outside of her IC piping that i'm buying... is this bad? do i need to remove this in order to let as much heat out as possible??? lemme know... thanks!!!
~Derek
Old Jun 29, 2004
UltimateStock's Avatar
UltimateStock is on a distinguished road
good question...bump for answer!
Old Jun 29, 2004
Speedracer32's Avatar
Speedracer32 is an unknown quantity at this point
ummm...the paint should be reflecting the heat from gettin in the pipes
Why would you want heat in the pipes when the colder the air the more combustible it is
The only thng you want hot is the exhaust gases spinning the turbine
the paint should be fine
Old Jun 29, 2004
REDchirp's Avatar
Ohhh ok... i thought that you wanted aluminum IC piping to let some of the heat out of the pipes while it's traveling to the ITM... wasn't thinking it was just for reflecting heat away from it... so which would be better then In your opinion??? leave the 1200 degree resistant paint on or use my trusty Aircraft grade paint remover and polishing them up with metal polish???
Old Jun 29, 2004
civic01vtec's Avatar
leave it go
Old Jun 29, 2004
REDchirp's Avatar
Just leave it??? It'll be fine?? i would be losing power from the paint keeping heat in the system? or it's not gonna affect the heat dispersion?? thanks
Old Jun 29, 2004
it will reflect the heat coming off of the engine. It will be better.
Old Jun 29, 2004
CivicsRdBest's Avatar
I was thinking the same thing... You should leave it because the engine will get hot and a lot of people want heat shields and stuff...
Old Jun 29, 2004
REDchirp's Avatar
oh ok... so then it's good stuff to have on the piping!!!! awesome... thanks guys...
