TurboXS RFL Type H Blow Off Valve BOV Turbo XS
Old Jun 27, 2004
SODJAZERO's Avatar
SODJAZERO is an unknown quantity at this point
Does anyone have this bov? If so how do you like it?
Old Jun 27, 2004
2k2redcivic's Avatar
2k2redcivic has a spectacular aura about2k2redcivic has a spectacular aura about
my friend has it on his dsm and its crazy loud. ill prob be switching to that 1.
Old Jun 27, 2004
StreetLevelPerformance's Avatar
Your Parts Guy
StreetLevelPerformance is on a distinguished road
Got it, selling it along with my SF kit. New custom kit will utilize an HKS SSQ.
Old Jun 27, 2004
SODJAZERO's Avatar
I heard it was made for hight boost apps... Would it still work for less than 10 psi?
Old Jun 27, 2004
dragoon's Avatar
doesnt start sounding real nice until around 14psi.
Old Jun 27, 2004
civic01vtec's Avatar
very efficent bov.........although the guys on honda-tech don't like turbo xs bov's. It is made for 30psi...........dober cut a couple coils on it and he likes the sound of it now.
Old Jun 27, 2004
droppin187s's Avatar
droppin187s is on a distinguished road
i am a fan of the type h-rfl. real good price!
Old Jun 29, 2004
ZdS03Civic's Avatar
ZdS03Civic is an unknown quantity at this point
Custom Turbo Kit Fund: $1.42
ROFL!
Old Jun 30, 2004
Demoncvc's Avatar
Demoncvc is an unknown quantity at this point
I just took some washers out of my BOV and it was fine. I had two washers in and it sounded great
Old Jul 1, 2004
SODJAZERO's Avatar
^^^ How many pounds are you boosting?
Old Jul 1, 2004
riceburnrex's Avatar
First to spool
riceburnrex has disabled reputation
That BOV works great for high or low boost applications, a friend has it on his WRX and has never had a problem.
It's REALLLLLLYYY loud... but if that's what you want, you'll be very happy with it.
Old Jul 1, 2004
Demoncvc's Avatar
5 and 7 pounds
Old Jul 2, 2004
Civic Type S's Avatar
Civic Type S is an unknown quantity at this point
I have it and Love it, I couldn't imagine my car with any other BOV..
Old Jul 2, 2004
ImportRacer2123's Avatar
K20 Member
my buddy had it on his 90 300zx TT.... loud as hell. hence the name RFL ( Really Fuking Loud) I went with Greddy Type S
Old Jul 2, 2004
SODJAZERO's Avatar
Im leaning between the greddy type s, and the rfl. By the way if anyone has a greddy for sale let me kno.
Old Jul 2, 2004
Big Baller L's Avatar
Nugget Garage Since 2004
sorry to thread jack, but are there any differences in sizes of bov's? I want the HKS SSQ, but im wondering if size has anything to do with it? Also what else besides a flange and a welder is needed to install on charge pipes?
Thanks
Old Jul 2, 2004
SODJAZERO's Avatar
Thats pretty much it. To get the flange welded on and to install. You gotta tune it tho, other than that its pretty simple.
Old Jul 2, 2004
First to spool
Size does matter somewhat... some BOV's only have one pressure release, while others like the HKS SSQ and Apex'I Twin Chamber have two, one small and one big. The small one opens up faster (because it's smaller and requires less pressure to activate) and gets some boost out quickly, while the bigger pressure release opens up under higher boost (above 4.5psi to be exact) and lets a lot more air out. The small valve helps to relieve pressure faster and eliminate compressor surge, while a monstrously huge BOV or one with only one pressure release valve that is bigger might get just a little bit of surge before the pressure release is fully open.
Many BOV's have twin pressure releases, and that is the cause for the different sounds under low boost and high boost on many BOV's. Usually they will be called a Twin Chamber or Sequential BOV if they have more than one pressure release valve.
Old Jul 3, 2004
What do you need to do in order to tune it?
^alright that helps alot! Thanks. I never really researched much on BOV's, so im guessing a two stage one is adequate for me. I just remember seeing a couple different sizes on a website, and was wondering if that has an impact? Like what size HKS do people run. It seems they are universal, but this site had different sizes.
Old Jul 3, 2004
SODJAZERO's Avatar
Well some bovs are adjustable and some are not. Like type s and the hks ss, those are adjustable. They have a screw at the top to adjust the "stiffness" on the spring that determins when the bov opens. The one that came with my maxref kit is not adjustable. Adjustable bovs give you more options for tunning. Like you dont want the spring too limp or it will leak under boost, and you dont want it too stiff or it wont open when the tb valve closes. RICEBURNREX would know more about it.
Old Jul 3, 2004
SODJAZERO's Avatar
You dont need much to tune it. Usualy an allen key and some plyers.
Old Jul 3, 2004
First to spool
You're exactly right. The adjustment on the HKS SSQ controls the spring for the smaller valve. The bigger valve is not adjustable.
Size of the blow off valve does matter... a bigger BOV can vent more air at a time, but that also means there is more of a delay while opening the larger valve, and it usually takes more of a pressure differential to open the valve, leaving you with some compressor surge. That's why dual stage or dual chamber BOV's are so effective, they release fast and a lot of air.
Old Jul 4, 2004
^okay that makes sense. So any suggestions on what size HKS to get? I saw a couple different sizes 50mm and 60mm, and I figured after reading you'rs posts that a smaller one would better suit a low/moderate boost set-up.
Old Jul 4, 2004
First to spool
If you are not going above 15psi, the 50mm is more than adequate. You can go bigger as long as it is a dual chamber/stage BOV, but there really is no need to.
Old Jul 4, 2004
^agreed...thanks for ur help...once again sorry to thread jack.
Old Jul 4, 2004
SODJAZERO's Avatar
^ No thread jacking here. Just some one wanting to learn.!!
Old Jul 6, 2004
^thats how I feel, but sometimes people get mad!
Thanks again for all the help...hks should be on the way soon!
Edit:what size mm is the turbo xs valve? The HKS one im looking at is 50 mm, but ive heard that 32mm is a better size for my application. Is this true? Or is it only because the turbo xs only has one stage of venting compared to the two stages of the hks?
Thanks
Old Jul 7, 2004
First to spool
Thanks
32 is kinda small for a BOV. I doubt that the TurboXS is this small, but it is possible. I did not see anything on TurboXS's website about them being a dual chamber either.
50mm is not too big for a BOV, it would be for a wastegate, but not for a BOV.
jessica19699
24
Jul 21, 2017 06:59 PM
Kenji_Shinomori
Jun 22, 2015 03:33 AM
Supramk3
Jun 11, 2015 11:13 AM
Supramk3
May 11, 2015 07:55 PM
cloudguy
Apr 28, 2015 05:02 AM
