twin turbo civic
Old Jun 26, 2004
bigkev3182's Avatar
bigkev3182 is an unknown quantity at this point
twin turbo civic
I was just wondering since there supra, 300zx, and others can utilize twin turbo setup, whats limiting a tt if say you had a fully built k24 or k20
Old Jun 26, 2004
abmerop18's Avatar
Jam out with your clam out.
lag would be crazy unless you built them with a smaller turbo for low RPM and a bigger one for high RPM, but the biggest factor is $$$.
someone actually did a TT civic on www.homemadeturbo.com if you search for it.
Old Jun 26, 2004
jwcardy's Avatar
SRT-4 owner with 2MCHPSI
jwcardy is on a distinguished road
room will be an issue too...
Old Jun 27, 2004
bigkev3182's Avatar
couldnt find it but thanks anyways i was just curious
Old Jun 27, 2004
MadWheel's Avatar
Premium Boosted Member
If I ever did that (which i wouldn't) I'd go with 2 T25 ball bearing turbos, not sequential, 1 for each 2 cylinders.
Old Jun 28, 2004
bic's Avatar
bic
bic is an unknown quantity at this point
twin turbo on a 4 cylinder is overkill. just get one turbo the right size.
Old Jun 28, 2004
RiceRocketeer's Avatar
Custom Titles are played out
RiceRocketeer has a spectacular aura aboutRiceRocketeer has a spectacular aura aboutRiceRocketeer has a spectacular aura about
It's in the eyes of the beholder what is overkill and what is not.
Old Jun 28, 2004
jonnyg's Avatar
E36 M3 Driver.
jonnyg is an unknown quantity at this point
a v6 is what is limiting a TT....not saying it can't be done. Ive seen a few pics floating around but that is just way to overkill, it would be all 'hype' and useless performance....like just getting TT just to say you have a TT...ya know?
Old Jun 28, 2004
Master's Avatar
Banned by Admin
ummm the supra is an I6
Old Jun 28, 2004
robbclark1's Avatar
Retired suspension supermod.
Nit picker. You get the gist. Anything with 3 or more cylinders per turbo can be justified.
There was a pic of that LS1 with 1 small turbo per each of its 8 cylinders. So anything can be done.
Old Jun 28, 2004
Master's Avatar
Banned by Admin
yes I know lol, I was just saying. Anyway wasn't that LS1 in and older chevy?
Old Jun 28, 2004
REDchirp's Avatar
REDchirp should not be trustedREDchirp should not be trusted
well... has anyone else noticed all the fastest Supra's switch to one HUGE SIngle-turbo setup because the single turbo setups are always faster.... that might be a clue there guys... just an observation
Old Jun 28, 2004
robbclark1's Avatar
Yep.
And yes, single turbos usually do run better, stronger and faster than twins. It is just fun to see what can be done sometimes.
Old Jun 28, 2004
acjones20's Avatar
acjones20 is an unknown quantity at this point
the supra was a sequential turbo setup (one little turbo spools up the bigger one). The Z was a V engine. inline engines really dont need twin turbos. Anyone that builds a supra for big power usually ditches the factory setup for a big turbo
Old Jun 28, 2004
acjones20's Avatar
Originally Posted by robbclark1
Yep.
not really, a V8 needs two PROPERLY sized turbos. Most people dont take the time to do the math and you get no power or lag. Ive never seen a single setup in the super street class at the strip (those are the BIG power turbo cars, like a 1500WHP mustang that runs)
Old Jun 29, 2004
nivenmk1's Avatar
nivenmk1 is an unknown quantity at this point
Uh, dumb rhetorical idea, but if you can push enough pressure with one turbo on your I-4 to blow it out from under your hood, do you really need two?
Lag might be an issue with that one turbo, but with two do you really think it will get any better when you have close to twice the mass to move with the same airflow?
Not heard anybody complain about the SF size turbo's and lag..... Heard a lot of raves on their power and seen a time or two where someone has blown their junk up with it.
Ah well, I suppose if you just must have a TT civic, rock on with your bad self... Just hold down the checkbook, cause it's gonna get rocked too.
cloudguy
Apr 28, 2015 05:02 AM
Boosted
Nov 21, 2003 11:03 PM
supraman
Nov 6, 2001 05:50 PM
HitlistCivic01
Oct 27, 2001 07:47 PM
