T28 Numbers?
Old Jun 21, 2004
HyaBoosta's Avatar
T28 Numbers?
Ok I am stuck as a step in my set up. If there are any boosted memebers out there with a T28 set up, what kind of numbers are you putting down? im not sure if i should go t28 or T3 manifold and turbo
Old Jun 21, 2004
Black2k2Ex's Avatar
Black2k2Ex is an unknown quantity at this point
i have a gt28r that came with the edelbrock kit on my 99 ex. it says its good for around 300 crank hp. i put down 204 hp at about 8 psi. i say if your not going to build up your engine to much then go with a t28, spools quick.
Old Jun 21, 2004
Speedracer32's Avatar
Speedracer32 is an unknown quantity at this point
yeh
IHI and t28 ,mistsu stock turbo spool quick
probably not all that great it your a commuter
depends on what you wanna do
beat people at the track and stoplights
or pull on them on the highway and see who the craziest
(usually i win that comp but i've slowed down lately)
Old Jun 21, 2004
HyaBoosta's Avatar
black 2k2 where in florida do you live.? wonderin if i can see how a t28 pulls.
Old Jun 21, 2004
HyaBoosta's Avatar
anyone else? lookin for t28 numbers off a 7th gen??
Old Jun 21, 2004
Silver_JS5's Avatar
Silver_JS5 is an unknown quantity at this point
also just wondering, what would you need to do to a stock engine to put in a t28??? would a little building be neccessary?
Old Jun 21, 2004
HyaBoosta's Avatar
nope no building neccessary. just normal turbo set up. and a manifold that has a t25 flange. im just curious what the output would be on our d17's at about a decent 8psi?
i also want to be able to reach 300whp after my engine build without loosing effeciency. would this be a good turbo match for the goal i have or would a t3 super 60 be better suited?
Old Jun 21, 2004
Black2k2Ex's Avatar
i live in plantation. about 30-45 minutes from miami. if you know where the sawgrass mall is, i live about 10 min. from there.
Old Jun 21, 2004
Silver_JS5's Avatar
so i couldn't blow my engine running a t28 with a t25 flanged manifold? even with everything else being completely stock internals?
Old Jun 21, 2004
HyaBoosta's Avatar
you could blow you engine for a ton of reasons but the turbo and manifold size don;t have anything to do with it. if you have a decent fuel system for the set up then you could run it at about 8psi (some people have done 10 on aclh. injection) on stock internals. anything higher with out internals and you risk blowing the head gasket, detonation,throwing a rod bent valve....ect
Old Jun 21, 2004
Silver_JS5's Avatar
so what would i should i do to be on the safe side? as far as internals are concerned?
Old Jun 21, 2004
drone007's Avatar
drone007 is an unknown quantity at this point
THANK YOU. hyaboosta this has been the most intelligent post i've seen on this forum yet.
Old Jun 21, 2004
HyaBoosta's Avatar
i'de say go the route im going. take your time and piece together your kit with quality parts. you can always find a nice price if you seach hard enough, just don;t buy cheap parts or else thats how your performance is gonna be. get the basics first see how your car handels the boost at maybe 5psi and take it from there some people have trouble running 5psi and some have no problems running 8psi. just make sure you get your setup dyno tuned.then from there see how it feels and what your output goal is then see how far you wanna take it on the internals.
Old Jun 21, 2004
HyaBoosta's Avatar
oh yeah black 2k2 i live right off 595 and 136th just 2 min from sawgrass mall. maybe we can meet up sometime so i can see how your setup is runnin. i wanna get a feel for what im getting myself into cause it looks like a gt28r garrett turbo is like 700 bucks easy. i wanna make sure. what do ya say?
Old Jun 21, 2004
Black2k2Ex's Avatar
ya man, whenever you want. i start school on thursday, but the latest i will get outta class is like 2:30. so just send me a p/m when you wanna meet up.
Old Jun 21, 2004
HyaBoosta's Avatar
i get out of work at like 5:30 where do you go to school?
Old Jun 21, 2004
Black2k2Ex's Avatar
i go to the central campus bcc in davie.
Old Jun 21, 2004
HyaBoosta's Avatar
you wanna meet up on friday?
Old Jun 21, 2004
Black2k2Ex's Avatar
sure, if you want to. just send me a p/m on like wednesday or thurs. tellin me where and what time.
Old Jun 21, 2004
HyaBoosta's Avatar
alright i'll hit you up on thursday.
Old Jun 21, 2004
Big Baller L's Avatar
Nugget Garage Since 2004
so any conclusions yet? Is a t28 turbo going to put out nice numbers or just quick spooling time? I guess the ratios would also affect it, but generally speaking what kind of power do they put out?
Old Jul 11, 2004
Bump for t28 or t25 owners
Old Jul 11, 2004
civicskater's Avatar
Chicks dig my scent
I dynoed my car again yesterday (T28) at 6psi completely tuned and with my custom 64mm TB,and at 8 psi heres the numbers..
6psi 169whp and 159lb ft (increase 3hp and 7lb ft)
8psi 188whp and 170lb ft
I was happy with my numbers, as you can see i have it set up for more torque(hit peak torque at 4600rpm). In 2 months im going to dyno again at 10psi and 12psi after i get pistons, rods, etc. and my alcohol injection workin 100%
Old Jul 11, 2004
HyaBoosta's Avatar
nice numbers. about the same as the SF kits t3 super 60 at 8psi
Old Jul 11, 2004
^those are some pretty nice numbers! What are the AR. ratios for you're turbo? I think i asked this already! If i could be around that range I would be extremely happy. Now all we need is a t25 owner to post up so we can compare the two.
Cant wait for the 10 and 12 psi numbers! Did you have alcohol injection for those two runs?
Old Jul 11, 2004
Chicks dig my scent
my compressor is .53 a/r and .47 a/r turbine. I used 50/50 methanol and water injection on both runs just to be safe...usually when i drive at 6psi i dont use it but im also not under full throttle all the time. Hopefully things will go as planned by sept and i'll be running another dyno(with video). I will also dyno with my friends RSX type s w/ hondata i/h/e and see if i can destroy his numbers.
Old Jul 11, 2004
^thats sweet. The turbo im looking at has a .64 turbine A/R and .60 Compressor A/R, but it is very very expensive. Around 1000 CAD. Its a BB turbo tho which is nice, but could be considered overkill for our cars I think. Its just hard finding a good deal on t28's, so im probably going to get a new one. Thanks for posting up you're numbers tho! Its helpfull to determine what I want to get!
Old Jul 11, 2004
Chicks dig my scent
no problem, yea the ball bearing gt28s rock. I'll probably step up to that next or a super 60 T3. But i think its worth it if you're going the custom route, its not that commonly used like the t25, t3, and t3/t4 and i think its perfect for a civics power output.
Old Jul 11, 2004
HyaBoosta's Avatar
big baller your looking at the garrett GT28 right??
Old Jul 11, 2004
Skater:yah the t28 seems to be around the size i want to get.
Boosta:Yeah I have a shop locally that can get me the gt28. Is that the same one you want to get? I think it would be very nice size for our cars with the a/r ratios. Not too big, not too small.
