where can i get weld fitting at?
Old Jun 11, 2004
03CivicEX03's Avatar
03CivicEX03 should not be trusted03CivicEX03 should not be trusted
brought used and he didn't give me weld fitting where can i pick one up?
Old Jun 11, 2004
bobbyd's Avatar
bobbyd is an unknown quantity at this point
WTF is a weld fitting?
Old Jun 11, 2004
Sorry, i don;t even know what it call lol. Is the thing that you weld it on your oil pan soo.. you can screw the oil line into it. It like a metal tube that sticking out from oil pan like this
Old Jun 11, 2004
this
Old Jun 11, 2004
Speedracer32's Avatar
Speedracer32 is an unknown quantity at this point
ebay
or got to pepboys, get a brass fitting and JB it
it all works
Old Jun 11, 2004
soo.. i just weld that thing onto my oil pan right?
Old Jun 11, 2004
there are different ways you can do it
either way your going to have to jack your car up, drain the oil, unbolt the oilpan and drill it. ( best to be done on a weekend and early in the morning incase you have to run tot he autopart store)
1.) You can take the one on the left( like me) drill the hole, and put this in there. On the inside you screw and bolt on it. Just make sure it's tight so it doesn't come off. The one on the right bolt to the drain side on the turbo.
2.) Now the one on the right has a plus. It can be used for both. you can use in on the oil pan as well as the turbo. What you do is after drill the hole ou have to drill two small holes beside the big one. These holes are for bolts. You get a gasket sealant to put under and around the flange and bolt it as tight as you can. Other use JB weld. good for up to around 600 degrees. works great. I actually had to use some today because of a small oil leak
3.) You can also just drill, buy the flange of ebay and take it to a local welder or muffler shop. ( this depends if you pan is aluminum or metal thou)
good luck
p.s. It's not as difficult as you think.
hope this helped
Old Jun 11, 2004
thanks a lots speedracer32
Where you get all those parts from? site? parts #. I'm new on turbo soo.. i'm still learning =) i'm scared of getting the wrong parts soo... if you can help me by parts # site to get the parts from. Thanks
Old Jun 11, 2004
http://www.horsepowerfreaks.com/Show...ProductID=5139
Is this going to work too? but is cost like 150 for kit ^^
or
http://www.fast-turbo.com/Turbolines.html
Old Jun 11, 2004
Do i need a Turbo Oil Return/Drain line kit and Turbo Oil Feed/Supply line kit?. Hope they come with thing that i can bolt into my oil pan.
Old Jun 12, 2004
www.stealthmodeperformance.com
guy name Steve runs it
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
GolNat
Nov 27, 2018 03:32 PM
Sep 27, 2015 11:33 AM
rnaodm
Sep 21, 2015 12:42 PM
Dave Brabant
Sep 12, 2015 08:39 PM
