adjusting cam gear--quick help
Old Jun 5, 2004
Okay, before I put this on, I need to know what to set it at other than zero. I have the DH ported head (milled down 1mm=higher compression), and my idle is really rough. The car shakes back and forth when I let off the brake from a stop. So do I need to advance or retard the timing? How much? Someone please help.
Old Jun 5, 2004
StreetLevelPerformance's Avatar
Your Parts Guy
StreetLevelPerformance is on a distinguished road
I'd have a tuner take a look at it before messing with cam timing. Sorry you are having all these problems.
Old Jun 5, 2004
Forget it. I'm finished messing with this stuff. Thanks anyway for your help.
Old Jun 6, 2004
Havok2k1's Avatar
Wicked Pissah Admin
With a milled head, you need to use a dial indicator to degree the cam in...
Old Jun 6, 2004
Care to elaborate on that? I'm willing to get a different cam gear and have someone install and tune it, but I'm not putting any aem stuff on my car anymore. Thanks for any help. I just want my idle problem fixed. Oh and the head is milled 1mm.
Old Jun 6, 2004
Havok2k1's Avatar
Wicked Pissah Admin
Something like this kit...
http://store.summitracing.com/partde...art=CCA%2D4796
I'm not sure if it works with the civic, but you get the idea of what you need...
Old Jun 6, 2004
Interesting. So you just need that and it works on the stock cam gear?
Old Jun 6, 2004
Havok2k1's Avatar
Wicked Pissah Admin
You degree the cam to stock specs using it... Or lets you add or remove degrees of cam timing.... It makes sure eveything in the geometric equation all lines up....
ricer_em2
May 11, 2016 08:09 PM
Tedverseti
Sep 29, 2015 05:41 PM
rovafa2002
Sep 28, 2015 06:57 PM
mnewcomb
Air Conditioning
Sep 26, 2015 11:02 PM
OptimisticWay
Sep 18, 2015 09:37 PM
