Car falling on its face in mid-range
Old May 24, 2004
civic01vtec's Avatar
Ok, if i am in mid-range (around 3000-4200 rpms) and i jump on the throttle and the turbo starts spooling, the car is falling on its face and it acts like it isn't getting enough fuel. Then after 4,200 rpms it is fine. I checked the fuel lines and they are hooked up correctly, that is if SF marked the fmu right. I used 3/8th's fuel line, i wonder if it is too big maybe
anybody have any ideas ??????
Old May 24, 2004
andyman97's Avatar
Turbo Guru
Fuel cut was the first thing that I thought. Maybe thre pressure switch on the fmu is lagging for some reason. Either way it sounds like you're detonating. Be careful or kiss your motor goodbye.
Old May 25, 2004
CyPhin's Avatar
CyPhin is an unknown quantity at this point
^^^ wouldnt the CELl light be flashing if that were true?
Old May 25, 2004
Drivetofast's Avatar
Supercharged k20a3
Drivetofast is an unknown quantity at this point
i had a poblem with the one way valve for the map sensor take that off and see how it runs you can alwase get a missing link for $50 insted of the crap from sf.
Old May 25, 2004
i already have a cel b/c of the IAT sensor
Old May 25, 2004
i have the ML........ I never installed SF's shitty map sensor
Old May 25, 2004
StreetLevelPerformance's Avatar
Your Parts Guy
StreetLevelPerformance is on a distinguished road
Maybe the black box isn't sensing boost and turning on the inline pump right away?
Old May 25, 2004
andyman97's Avatar
Turbo Guru
Do you have a fuel pressure gauge? That will tell you what is up with the pump just by watching it when boosting.
Old May 25, 2004
Your Parts Guy
Hard wire your inline pump like the rest of us that dont have the black box did. At least that will elminate the possibility of black box failure.
Old May 25, 2004
CyPhin's Avatar
doesnt matter. it will actually start flashing.
My cel starts flashing in 3rd and 4th gear when i have cvs bought 91% alcohol in the tank.
BUT when i run without the alcohol ... with nothing the car runs 100% better.
Try using real Methanol. I bet that solves alot. I have 2 hour drive to get my hands on some so i have yet to do so.
BTW... WHAT PSI are you at? CAUSE i notice problems after 6-7psi with the alcohol.
but i run daily at 11 with no alcohol and no problems.
Old May 26, 2004
js4uhaterz's Avatar
js4uhaterz is an unknown quantity at this point
Question alc injection or meth injection
where can i get alc injection or meth injection....and how does it work and activate>>>>>
Old May 26, 2004
CataClizMik's Avatar
CataClizMik is an unknown quantity at this point
u can get it through SF. all it is , is an injector, and a pressure sensor switch which activates it.
Old May 26, 2004
MadWheel's Avatar
Premium Boosted Member
11psi without alcohol on what car? You sure it's 11psi?
Old May 26, 2004
C2i0v0i1C's Avatar
SuperMODrizd
u people running double digit boost on a stock motor, with just some alcohol going in, are a bomb ticking down to zero.
ive got alot more **** done that most people on here and still i dont do the stupid stuff u people do, i dont run double digit boost unless at the track, or can forsee something necessary on the road. i dont even have a setting on the boost controller for a setting that is double digits and street usable, i have to load a emanage map and use race gas for my double digit setting
Old May 26, 2004
ive ran 11psi myself since august madwheel. .. alcohol (not methanol) causes problems so i run nothing. and the car runs great
C2 - i beat my car up everyday. change the oil once a week. i took the block apart last month to check for signs of wear, and leaning. but everything is A OK.
i gotta friend building my k20 block from the ground up as we speak.
when its done.. im gonna shut the wastegate and let the turbo spool as high as it can go and just watch the d17 BLOW
Old May 26, 2004
Havok2k1's Avatar
Wicked Pissah Admin
wow, you must be a busy person...
Old May 26, 2004
ZdS03Civic's Avatar
ZdS03Civic is an unknown quantity at this point
Why dont you sell your motor to exospeed.com or something? They need motors to develop parts for our cars.
Old May 26, 2004
MadWheel's Avatar
Do you have an LX then? I suppose that may be possible on race fuel. But the EX has too high of a compression to safely run that kinda of pressure...
CarStuff
Dec 6, 2020 12:52 PM
Ian SFBA
Interior DIY
Apr 25, 2015 02:25 PM
mrohitredd
Apr 15, 2015 08:13 PM
CiViCPrAnInG2k1
Nov 2, 2001 02:49 PM
AL
Oct 18, 2001 03:01 PM
