Lx to Si?
Old May 19, 2004
03_civic_03's Avatar
03_civic_03 is an unknown quantity at this point
Lx to Si?
Is it possible to change the head on a 2003 lx civic to si head? I seen other non-vtec motors doing head swaps to get vtec
For example my friends has ls vtec on his intregra and its very fast!
Old May 19, 2004
RiceRocketeer's Avatar
Custom Titles are played out
RiceRocketeer has a spectacular aura aboutRiceRocketeer has a spectacular aura aboutRiceRocketeer has a spectacular aura about
lol, no its not possible..
Old May 19, 2004
cambo's Avatar
I wish I was asian
2003 lx
engine- D1A3
2003 si
engine- K20A3
So no. you can't just swap the head, 2 different series engines. The Integra LS used a B-Series block and a non-VTEC B-Series head. You can swap a D17A2 head onto your D17A3 block, but on a SOHC motor, it's not worth the effort.
Old May 20, 2004
Spider883's Avatar
9K Redline Owns U
if you all would take notice that he is from canada.. hench the si to him is our ex... ex/usa si/can. si/usa sir/can.
Old May 20, 2004
porcChop's Avatar
porcChop is an unknown quantity at this point
both civics are using the same block so if you want VTEC
you'll need the vtec head, controller & ecu
I'm not shure what else you need
my research is on putting in a k24 (accord) block
with a k20 (rsx type s) head
Old May 20, 2004
jdm_bb's Avatar
jdm_bb is an unknown quantity at this point
2001 LX to K20 Si
Will i need to get the sub frame? and also the gearing is that a problem?
and will this be easier than doing the type s or type r swap?
Old May 20, 2004
andyman97's Avatar
Turbo Guru
Well, base off of what spider said, if you are going from a d17a1 to a d17a2, you can simply do a headswap. Just find a new head and ecu. You can run the vtec wire on the ecu to the vtec solenoid and you're good. Not a difficult thing to do at all.
Old May 21, 2004
how much more horsepower will it give you?
Old May 21, 2004
dragoon's Avatar
next to nothing.
Old May 21, 2004
porcChop's Avatar
you'll go from 115 to 127hp
Old May 22, 2004
Mistro's Avatar
Mistro is an unknown quantity at this point
wow its that simple? Just the head and ecu? then run the vtec wire and thats it?! How much would a new ecu and head run for approx?
Old May 22, 2004
porcChop's Avatar
an ecu could run you up to $500 - $600 Can
try going to the junkyard and and check to see if there's a civic si
prices for an ecu should be cheaper
Old May 23, 2004
Mistro's Avatar
Couldn't find an ecu but a new cylinder head can run from about $700-800. :O
Old May 23, 2004
ViNRoCk8's Avatar
#1 S2000 Fan
In my opinion 700 to 800 bucks insn't worth it when you can pick up a K24 for like 750-1500
Old May 23, 2004
porcChop's Avatar
just do the swap you'll be better off
Old Jun 9, 2004
whoami's Avatar
whoami is an unknown quantity at this point
maybe not
You might not get all the way to 127hp because the exhaust manifold on the EX/ Can Si is different from the LX manifold. Am I correct here? Are there any other differences in the cars that anyone is aware of that would detract from the 127hp figure?
Is the conversion really this simple? A head and an ECU? You could probably get something for the old head and ECU so it may be be that expensive.
