engine swap
Old May 3, 2004
bigkev3182's Avatar
bigkev3182 is an unknown quantity at this point
engine swap
has anybody heard of swapping a V6 accord engine into a '02 civic? Is this even possible? If so does anybody know of somewhere you could buy the engine?
Old May 3, 2004
guns's Avatar
Skyline R33
guns is an unknown quantity at this point
Re: engine swap
I think the bigest motor that will fit is the K24. If you want power get an S2000 head and put it on a fully built K24 block and boost it to 20psi.
It would smoke any V6 or V8 out there.
Old May 4, 2004
kcm's Avatar
kcm
kcm is an unknown quantity at this point
i wanted to do this but with a c32 (drop a legend motor into an older civic) instead of the j30 engine... in the long run if it was possible, your front end would be so heavy... second of all if you had the money, it would be a hell a lot more cost effiecent to drop a k series motor, and if you really had the money get the type r tranny... and then with the motor drop in new internals and you wil get much better handling and overall performance
Old May 4, 2004
Texas Rice's Avatar
Texas Rice is an unknown quantity at this point
Is that a possible swap, the S2000 mated with the k24? Correct me if I am wrong, and I am sure that I am. Wouldn't that job need quite a bit of fabrications? Also, you can kiss that great mileage away but if your spending upwards of 10k on your engine then I guess money isnt a problem for you.
Old May 4, 2004
Jodster's Avatar
Post Whore General
S2K head with a K24 Block???? Nope. Its been tried. Doesn't work.
Old May 4, 2004
robbclark1's Avatar
Retired suspension supermod.
anything is possible if you have enough money, but I wouldn't put a v6 into a civic. The best you can do is a k24 with a k20 vtech head. or just a k24.
BTW we always get this questions and then the person never shows up again to post.
Old May 4, 2004
ViNRoCk8's Avatar
#1 S2000 Fan
They probably just read it and leave....lol
anyway when the K-series came out they thought you could put an F20C head on it.......Can't do it....just a rumor.
But of course anything can be done with money.......IE: V6 in Civic, which i am really surprised has never been tried before with all these rich retards out there.
Old May 4, 2004
Havok2k1's Avatar
Wicked Pissah Admin
LMAO, that is soooo true......
Old May 4, 2004
bigkev3182's Avatar
so what kind of power would a k24 with k20 heads be around, and would forced induction be ok with that setup
Old May 4, 2004
Havok2k1's Avatar
Wicked Pissah Admin
BTW:
http://www.7thgencivic.com/forums/se...der=descending
Old May 5, 2004
bishoprd's Avatar
bishoprd is an unknown quantity at this point
i wanna know if its any turbo kit on the market for the civic o1' and which is better get a K20a motor swap or just get a turbo kit for the d17
Old May 5, 2004
Jodster's Avatar
Post Whore General
^^^^^^^^^^^Yes there is a few kits on the market. Search and you'll find them. As for turbo or swap, that depends on how much money you want to spend.
Old May 5, 2004
Texas Rice's Avatar
I've posted this before and I will do it again because its bada$$. Dyno'd Hp:185 Torque: 155 with a LOW compression ratio that will make nice numbers under boost.
Old May 5, 2004
Jodster's Avatar
Post Whore General
The K24 Motor has a 9.7:1 compression. So boosting it would not be a problem. With 8psi the K20A3(SI motor) makes about 270whp. Now the K24 factory should make about 300whp just because of the bigger deplacement. Add the K20A2 head for the true IVtec and I don't see why you wouldn't see about 315-320whp with only 8psi. And that would be plenty enough power and not be that much of a strain on the motor.
Old May 5, 2004
Havok2k1's Avatar
Wicked Pissah Admin
Did you even read one single thread in this forum besides this one?
Old May 5, 2004
Jodster's Avatar
Post Whore General
Hahahahahaahahahaa
Old May 5, 2004
Texas Rice's Avatar
No turbos, we are all n/a autocrossers.
RicoSuave
May 20, 2015 01:57 AM
cloudguy
Apr 28, 2015 05:02 AM
MyOtherRideIsBritney
Jan 20, 2002 03:16 PM
robbclark1
Dec 12, 2001 12:18 PM
supercivic01
South
Nov 30, 2001 11:27 AM
