Room after swap
Room after swap
For those of you with a K swap for uch extra room do you have under the hood. I'm looking to do the A3 then later doing the greddy turbo, but don't know if theres enough room
Retired - SoCal FI Mod
there should be pleanty of room under the hood after the swap considering that the rsx and civic have the same frame... i've personally seen a k20a2 swap /w turbo at stafford's shop... i thought it wouldn't fit at first either, then he bolted up the kit and closed the hood... done deal..
Originally Posted by CivicSouldjaEX
Would a JRSC fit on the swapped K20A2?
typeS charger will deffinetly not fit however the si charger pulley sits right where the powersteering pump on the A2 goes.. the si can put it there since we have electrical power steering..
on the supercharger subject spider how do you like yours? I am contemplating getting one once i know hasport got it to work and i see some numbers.
well im selling the sc for the cybernations stage 1 kit.. i just need more power and im already running more boost then i should on the sc
BOOSTED HYBRID
already have kpro on an ecu sitting in my room.
.. everyone knows that after a month of the cn kit i will have some custom stuff made of it anyways.. i only kept the sc for 2 months and same goes for the turbo most likely.. then ill end up with a k20a
.. everyone knows that after a month of the cn kit i will have some custom stuff made of it anyways.. i only kept the sc for 2 months and same goes for the turbo most likely.. then ill end up with a k20a Custom Titles are played out
Originally Posted by icebergslim
Why dont you go with a custom setup. The parts sold with the cybernation kit arent that good. Do it right the first time or you'll end up like me and DC5@EM2. Both of us are changing our cybernation setups. The only reason to go with cybernation before was the black magic, which made it run decent. Now that the K-pro is out, anyone can make a custom setup. The only part thats pretty hard to find is a manifold, since I was looking for an equal length. If you need help searching for parts let me know. I got my car going in the shop this weekend. I should have some good results with the new setup.
Let me know where you get your manifold.. PLEASE!
Thanks.
Scout1
Oct 5, 2015 01:33 PM
ThatGuy913
Sep 28, 2015 05:35 PM
Touge
Sep 18, 2015 12:13 AM
ZoSoIV
Sep 17, 2015 07:17 PM
