Fuel injector testing fund - help determine if the K24 is worth the money!
Well guys, I received word from Mirage regarding the flow test of the K24 CRV injector.....Needless to say I'm disappointed!
Here is the PM I received:
Fairly disappointing, huh? It looks as if the K20, ala RSX type S injectors are the largest to be tested to date. I myself will probably get some of those to tide me over (they should be good for around 200hp at 43 PSI if Honda did their math correctly). Other injectors that are still available to test include:
2003+ Honda Accord
2004+ TSX
I know these are the same 'style' injectors as the K20 and K24 use (the TSX actually is a K24, but with different HP ratings than the CRV) - so they may be another viable solution. Unfortunately I'm not going to fit the bill again to test them (I only received about $15 in donations from a few grateful members, plus free testing from Mirage - THANKS AGAIN GUYS for helping out!!).
The base fuel flow on the sample injector @ 43.5 PSI is 273 cc/min. The flows measured at different pressures are below. Using 43.5 as a base and the standard pressure change equation (new flow rate = sgrt(new press/old press) * old flow rate), the flow rates measured as a function of change in fuel pressure fits the theoretical flow rates pretty well:
Test Press Measured Theoretical
40 PSI 256cc/min 262cc/min
43.5 PSI 273 cc/min 273cc/min
45 PSI 280 cc/min 278cc/min
50 PSI 295 cc/min 293cc/min
60 PSI 322 cc/min 320cc/min
2003+ Honda Accord
2004+ TSX
7thgen Power Maker
2003+ Honda Accord
2004+ TSX
2003+ Honda Accord
2004+ TSX
PM me, we'll talk about getting you one free RSX injector or something. Ok? I want to help the cause.
one question
i know i probably missed this somewhere but is there anything
special that i need to do to make the k20 injectors fit? i just dont wanna order them and not beable to use them. thanks!
I've PMed you josh, however - I plan on trying to test if things fit this weekend sometime if I get the injector back from Mirage. At this point the only thing I forsee a problem with are the mounting studs on the intake manifold being too short - they will probably need to be modified.
Ok - I was bored tonight so I started to play around with my spare intake manifold. To fix the stud length issue here is what you need to do.
Where the fuel rail mounts to the intake manifold, take some channel locks and CAREFULLY unscrew the studs which are mounted in the metal spacer of the manfold.
With a little effort they will come out. I went down to my local lowes store (better than home depot if you ask me - they have a LOT more hardware there!) and bought some M6x1.00x40mm stainless steel cap screws (their actually bolts). The 40mm length ones should work, in fact you may have to cut them (I won't know for sure until I can test fit the injectors). The other thing you'll need are nylon spacers. I bought a pack of 5/8 x 1/4 x 3/8 spacers, and I think they will fit perfectly. If not, get some longer ones and cut them down if necessary. Oh yeah - don't forget to use locktite if you do this, as the bolts may come loose.
