Fuel technical question
Old Apr 4, 2004
jwcardy's Avatar
SRT-4 owner with 2MCHPSI
jwcardy is on a distinguished road
alright...i have been talkin to a local mechanic about my SF turbo kit and he was wondering how the SF fuel setup worked...i really didnt have an explanation for him cause SF hasnt really told us...i basically just told him that it ups the fuel preasure because the stock fuel pump cant keep up with the positive boost...keep in mind that he hasnt messed with boosted cars before so this is what he was asking.....he told me that most modern cars basically have a high and low setup on the fuel pump and that the factory fuel pump should be able to supply more than enough fuel to the car meaning that all you would need is something to control the fuel like a FPR or bigger injectors or a fuel computer of some sort....so why would the factory fuel pump work????? can it just not keep up...why wont it...i didnt have an answer for him because i didnt know....well, i want to know...so those of you who have experience, take a shot at it......
Old Apr 4, 2004
RiceBuRNeR's Avatar
Turbo Member
Our cars opporate at a fixed fuel pressure, thats how the returnless system works. From what I understand the SF kit uses an inline fuel pump to raise the fuel pressure as the level of boost increases.
Old Apr 4, 2004
jwcardy's Avatar
thanks....that would answer his ?
Old Apr 4, 2004
civic01vtec's Avatar
i don't understand what you are asking wes ?
Old Apr 4, 2004
StreetLevelPerformance's Avatar
Your Parts Guy
StreetLevelPerformance is on a distinguished road
He also wanted to know if there was a way to get more out of the stock fuel pump. I think you should get an aftermarket pump anyways since you have to drop the tank to block off the FPR.
Old Apr 4, 2004
RiceBuRNeR's Avatar
Turbo Member
I cant think of the manufacturer but I saw a fuel pump controller in summit racing thats suposed to raise the voltage to your stock fuel pump as boost increases but I dont know how safe that is......I dont think you want your fuel pump to overheat and burn up inside the gas tank.....
Old Apr 4, 2004
opto_isolator's Avatar
Again - as posted before, SF's fuel system raises the pressure accordingly as boost increases. This forces the injectors to meter more fuel per cycle than at the standard 45 PSI - so that's how they add more fuel....
Old Apr 4, 2004
RiceBuRNeR's Avatar
Turbo Member
Isnt that basicly what I said?
Old Apr 4, 2004
yeah.........
Originally posted by opto_isolator
as posted before
Old Apr 4, 2004
jwcardy's Avatar
thanks guys...i really wasnt sure how to answer his question...i am doing the return setup soon...and yes, i am gettin a bigger fuel pump...i wasnt suggesting that i was going to use the stock one...he just wanted to know why i couldnt.....and exactly what the SF fuel system did....i didnt really know how to answer his question...
Tedverseti
Apr 23, 2020 01:45 PM
werdnahall
May 17, 2015 11:37 AM
superstanko
Apr 28, 2015 04:38 AM
viper775
Dec 9, 2001 10:52 PM
