installing nitrous ?
i have a 2002 honda civic ex and i wanted to know where do i need to access the main fuel for the nitrous management unit on the zex wet kit
also where is a good place to mount my purge kit
thanx in advance
thanx in advance
BOOST JUNKY
There's a fuel line on the engine bay. You will need to cut it and install a "T". I'd take pics for ya and show you but my digicams battery is dead (oh yeah and i don't even have my car right now. LoL).
You can mount the purge solenoid to pretty much anywhere you want. As long as the line that goes to it (not the ss n2o line the actuall line where the n2o shoots out of) has access to be placed where you want it to shoot. Honestly....as pretty as purging into the atmosphere is...I recommend routing it to cool the n2o and fuel solenoids. But that's just me.
Either way.....wherever there's metal you can mount that solenoid. If you can...you can even make a bracket for all of your solenoids and mount them all in the same location somewhere in your engine bay.
Custom Titles are played out
I've always wanted 2 purge valves coming out of my z-3 fenders.. I think that would be sexy..
Just an idea..
You could have one mist over the top of the engine and it could be like a "stage 1 engine cool down".
<--- dumb
Just an idea..
<--- dumb anyone with nitrous on an automatic, i got it on mine and it does pull harder but not as hard as i thought it seems like i am running like low 16's or so but i thought it would be better and specs from anyone else or info?
what will that do? Cant think of any noticable advantages to this
BOOST JUNKY
Hmmmmm i dunno i think the advantage is pretty noticeable. LoL Atmosphere vs. cooling a solenoid(s) that tend to get hot. Especially on a night when you're getting a considerable amount of runs in...i.e. a track night.
last night i just lost to a z24 cavelier running my 50 shot, somethings wrong or something b/c im just not pulling very hard could it possibly be my fuel lines where im not getting enough fuel to my engine or something i dunno im just kinda pissed b/c the nitrous only gave me like .5sec improvment somethings gotta b wrong
If you're running lean, your motor will let you know pretty quickly. Check for N2O line kinks or pinching. Pull your jets out and purge the N2O line to clear out debris. Make sure your nozzle is pointing the toward the head. Make sure your switch is actually working...
alright b/c i jsut have it sitting in the spot where your intake sensor is suppose to go i thought that was kinda convenient to put the nitrous nozzle there so ill just drill a new hole so the nozzle faces the head
Originally posted by keepin_it_clean
u need to have that airflow sensor in there, otherwise your engine will run like crap. the ecu tells the engine what to do based on those sensors. i just drilled a hole in the rubber hos attaching the intake pipe to the throttle body, and stuck it in between the two. Like this:
no where on my nx kit manual does it say any distance from the tb...many many members here have it mounted right there, i do, and that is acutally kgjracing's picture on his car. has worked just fine for me for awhile now, and havent heard about anything bad happening to it.
My NX manual says 2-6 inches from the throttle body. My nozzle is probably about 2 inches, maybe less.
can anyone post pics of where the fuel line is in the engine bay? or describe where to look.
and when making a T in the line, you just cut the line, put the on the T, put hose clamps on and wahlah you're done? will fuel spill everywhere when the line is cut?
thanks for the help.
I'm suprised you're asking for pics. Just look under you hood and it shouldnt be hard to find. Make sure you pull your negative battery cable off before u attempt to do that. Yes, fuel will more than likely squirt everywhere. Just put a rag over it. Installing the T fitting in the fuel line was a little bit of a pain because you have a rubber hose and then u have a hard plastic hose on the inside of that. Getting the T fitting to go inside of the hard plastic hose was bi*ch of the whole thing. Better make sure you put the clamps on pretty damn tight or else you're gonna have a leak more than likely. Eventually I think I'll convert it to a stainless line.
mjdiaz89
Jun 21, 2016 09:26 PM
OptimisticWay
46
Oct 15, 2015 02:16 PM
17
Jul 23, 2015 11:48 PM
EM_WON
Jul 22, 2015 06:49 PM
