too rich?
Old Mar 16, 2004
kikoman0's Avatar
kikoman0 is an unknown quantity at this point
too rich?
Hey guys. I'm just wondering HOW rich all you turbo 7th gens are running. Man i'm polluting the air like crazy. So my exhaust gas comes out smells a lot and people following me always fall back or pass me cause of so much gas. I was wondering if there was a way to tune the SF fuel system to be less rich cause it seems hella rich. My a/f gauge just goes way green to the right side. When I'm idling sometimes on cold days it seems like my car is engulfed in a cloud of gas haha. Alright thanks for the help.
Old Mar 16, 2004
StreetLevelPerformance's Avatar
Your Parts Guy
StreetLevelPerformance is on a distinguished road
E-Manage or V/S-AFC and tune.
Old Mar 18, 2004
guns's Avatar
Skyline R33
guns is an unknown quantity at this point
Is there anyone with SF kit and the VAFC2? What kind of settings are you running? Vtec control, etc...
Old Mar 18, 2004
BoostedCivicZex's Avatar
Proud Srt4 owner
I got the sf kit and a s-afc, im still runing a little rich. I can smell the fumes from behind the exhaust
it could be also that kikoman doesnt have a catalyic converter since he has the dx........
Old Mar 29, 2004
jwcardy's Avatar
SRT-4 owner with 2MCHPSI
jwcardy is on a distinguished road
i am ordering the safc2 this week and plan to get it dyno tuned as soon as it gets here, so i will let you guys know
Old Mar 29, 2004
guns's Avatar
Skyline R33
Who with boost has gotten the VAFC2 to tune a SF kit? If you are under boost isn't the MAP sensor at 0psi and the fuel injectors putting out max fuel?
I am confused about VAFC2 and turbo.
Old Mar 29, 2004
MadWheel's Avatar
Premium Boosted Member
I have the VAFC2 and the SF kit, the kit got upgraded. The engine is being replaced by a built shortblock from DH. I actually had to turn up the fuel a lil bit cuz of the much larger turbo.
I suggest just getting a VAFC2 and going to a dyno shop and getting it done the right way, no guessing.
Old Mar 30, 2004
mndthegap1's Avatar
here is a question.... i have the autometer pro comp air/fuel gauge.
and when i start the car.. it starts off lean and after about 15-20 secs. it goes to rich, then back to lean the back to rich.
when i hit the gas, it starts lean and then shoots to rich and back.
i thought it was supose to stay within stoich (sp)
is this normal and if not what would correct it ?
should i get the s-afc or VAFC2 ?
Old Mar 30, 2004
MadWheel's Avatar
It's perfectly normal. It's your ECU balancing the fuel ratios. That and your o2 sensor isn't anywhere close to being as accurate as a wide band. Buy the AEM wideband sensor and your mouth will drop when you see the difference.
Old Mar 30, 2004
mndthegap1's Avatar
thanks for the info....
do you know of any good places where i can get it ?
the kit runs about $450 ?
Old Mar 30, 2004
MadWheel's Avatar
correct.
not too sure on where the best place to buy is though... sorry bout that
Old Mar 30, 2004
sspem2's Avatar
em2
what do u guys suggest with a turbo? the e-manage or the vafcII? whats easier to understand to tune like a noob myself to turbos.
Old Mar 30, 2004
MadWheel's Avatar
For ease go with a VAFC2. Very practical, allows you to tune vtec, and 2 diff fuel maps according to a user-selectable low and high throttle position.
For more power and greater potential go with an emanage. This is nice if you have a laptop or plan on spending about 4-500 bucks on the profec e-01. It allows you to do the same as the VAFC2, but with additonal injectors, you can tune ignition timing, injector duty cycle (including additional injectors), and fuel maps accpording to boost pressure.
If you are interested in a VAFC2, I have on listed on ebay, and on the civic website.
EBAY:
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2470829532
7thgen:
http://www.7thgencivic.com/forums/sh...59#post1907859
Old Mar 31, 2004
Havok2k1's Avatar
Wicked Pissah Admin
The SF FMU only works under boost....
If you really want to use the SF FMU, one way to adjust it is to get the vortech FMU with bleeder valve so you can tune the amount of FP added per boost instead of the set amount it currently has (either 6 or 8 to one)...
The other electronics that people mentioned above will do the same too...
Be careful and make small adjustments irregardless of whether you adjust the fuel electronically or mechanically...
Old Mar 31, 2004
7thgencivic9's Avatar
7thgencivic9 is an unknown quantity at this point
hey guyz i'm tryin to learn a bunch about engine and turbo stuff and i was wondering wut the heck ya'll are talkin about with this e-manage and s-afc and VAFC2? wuts the difference and wut do they do for your car?
Old Mar 31, 2004
Your Parts Guy
Best way to find out information that has been covered many times is to search.
Old Mar 31, 2004
yeah i've searched some but haven't found any posts that really go into the basics...the people that talk about it on here already know most everything about it and are talkin bout the little things about it...but i'll keep lookin
Luluharp
Sep 27, 2015 11:56 AM
2.0.0.2
Sep 14, 2015 06:38 PM
Tommy Cohen
Jul 22, 2015 07:54 PM
RiceBuRNeR
Mar 2, 2003 02:33 PM
