When would you put a turbo on?
Old Mar 7, 2004
INCivic's Avatar
INCivic is an unknown quantity at this point
Question When would you put a turbo on?
I have the cash to put a turbo on now. (went ot the boat and hit big last night!! )
what i was wondering is when is a good time to [ut on a turbo?
Would you wait until you a pretty good amount of miles on your car(i have 9,000, which isnt very much) or would you put it on as soon as possible and just say fawk the warranty?
im kinda torn between the warranty and the life of the car and speed. how much is a turbo gonna affect the life of the car. its my daily driver and i wont have the boost up until the weekends and even then, it wont be up too far unless im gonna race or something.
please give me some feedback on this
Old Mar 7, 2004
hoho's Avatar
hoho is an unknown quantity at this point
turbo is the way to go~ hahaha
Old Mar 7, 2004
88AccordDX's Avatar
Freedom costs a Buck o'Five
88AccordDX has a reputation beyond repute88AccordDX has a reputation beyond repute88AccordDX has a reputation beyond repute88AccordDX has a reputation beyond repute88AccordDX has a reputation beyond repute88AccordDX has a reputation beyond repute88AccordDX has a reputation beyond repute88AccordDX has a reputation beyond repute88AccordDX has a reputation beyond repute88AccordDX has a reputation beyond repute88AccordDX has a reputation beyond repute
Turbo can affect the life of the car because when you hit the boost, your engine does 100 times more work 100 times quicker because the car doesnt normally go in those RPMs everyday. And if it's your daily driver, then I guess have a boost controller installed and tune it down for the day and crank it up at night.
I'd go with hoho. "Turbo is the way to go!"
Old Mar 7, 2004
DistinctiveBP's Avatar
Shows No Remorse
DistinctiveBP is an unknown quantity at this point
congratulations!! you lucky fawker!!
if it was me id probably put the turbo on right away
Old Mar 7, 2004
gotti's Avatar
boost that bitch.
Old Mar 7, 2004
INCivic's Avatar
lol, thank you!
i would definetly go with a boost controller for just that reason. i dont want all the wear and tear of the turbo all the time. i want this car to last me til 100,000 easily.
anyone else have some input?
Old Mar 7, 2004
CuRiOuSfIsH's Avatar
Back From The Banned!
Boost controller AND turbo timer! = )
Old Mar 7, 2004
IronFist's Avatar
How does it hit rpms it doesn't normally go into? As long as you keep it below redline those are "normal rpms," aren't they? I redline my car almost every day with no turbo. Now, granted that at higher rpms there's more wear on the engine than at lower rpms, but it's still fine as long as you keep it out of redline (and you don't go driving around in at 6500 rpm for extended periods of time).
Old Mar 7, 2004
civic01vtec's Avatar
turbo will cost you about $4,500....that includes turbo, gauges, boost controller, plugs and a clutch
If you are worried about warranty, then don't do it yet.
And as far as the engine not lasting as long.......that is b/s. If you properly maintain and tune ur engine then you will have no problems.
I know someone that has a D16 that runs 10 psi daily on a stock bottom end and has over 180,000 miles on his car and has no problems whatsoever.
Old Mar 7, 2004
That is right... as long as you can control the car, and not have the car control you, it's ok. The RPMs will pick up faster, but if youre ready, should be ok!
Old Mar 7, 2004
INCivic's Avatar
well, ****. i thought i had enough to get one right now. i still have a little bit to go. i wasnt giving that much for all that stuff, but i was just going ballpark in my head.
the d16 makes me feel better, though. how many miles do u have on ur car?
Old Mar 7, 2004
SpdRcrChk's Avatar
BOOST JUNKY
SpdRcrChk is an unknown quantity at this point
Put it in as soon as you have the money for it.
Old Mar 7, 2004
RiceBuRNeR's Avatar
Turbo Member
I put my turbo on w/ over 55,000 miles on my 01 vic. The sooner the better.
Old Mar 7, 2004
civicskater's Avatar
Chicks dig my scent
ill have 21,000 when its on....hopefully, cant fauking wait!! hurry up spring break
about warranty, oh well...hehe, no problems with the car at all yet
Old Mar 7, 2004
41,000 and still not boosted
Old Mar 7, 2004
C2i0v0i1C's Avatar
SuperMODrizd
my new motor had 8k
Old Mar 8, 2004
kevin78's Avatar
kevin78 is an unknown quantity at this point
the kit costs 3100 you dont need all those other stuff right away the only thing you really need or would be a very good idea to have at first is a turbo timer ....unless you're a mechanic alot of gauges r a waste of time your stock clutch will last ...catalyst's car was completely stock when he had the stage 1 kit on it ..... and as far as the engine lasting, an engine for our car would cost you 300-500 $ on ebay ...you only live once man if you have the money boost it
Old Mar 8, 2004
SpdRcrChk's Avatar
BOOST JUNKY
ummmm yeah...a turbo timer isn't crucial. you can just sit in ur car for a couple minutes. What's more crucial is a boost controller, and a boost gauge. You wanna know if you're spiking. Alot of gauges aren't necessary you're right. Most of them are just bling bling, but u wanna see what you're boosting, and you wanna see your a/f.
Old Mar 8, 2004
ummm......the base kit cost 3,100 b4 upgrades.....mine was 2,900, then $3,400 after upgrades. I spent $400 on gauges....u need boost and a/f. You don't need a turbo timer. You don't need plugs.....but if u were smart u would install colder plugs. And almost every person that is boostin has needed a clutch after a few thousand miles. There is one member here that can't hardly even chirp the tires going 1-2. And as far as a motor only costing a couple hundred.....what about labor to swap the motors and the downtime of a daily driven car.
Old Mar 8, 2004
88AccordDX's Avatar
My bad about my theory on the engine not lasting as long.
I figured hitting the high revs too fast and too soon (with a turbo and all) would slowly wear the engine's power as well as its life.
But most of you guys know more than I do.
Old Mar 9, 2004
kevin78's Avatar
maybe its just me but what r u gonna do if you have all these gauges and u spike ? unless you have an ebc that has some kind of warning feature you're pretty much azzed out or am i wrong ? and while we're on the topic has anyone ever heard of pop of valves? they are supposed to be some kind of safety feature to prevent damage when spiking occurs..
Old Mar 9, 2004
i think it's just u........i am using a MBC, so i need a boost gauge to tell me how much boost i am running. I need a a/f guage to tell me if i am leaning out. I need a oil pressure gauge to tell me if that i have a possible leak that i am no losing too much oil.
pop off valves.....a.k.a. Blow off valves.....no, i never heard of them
Old Mar 9, 2004
StreetLevelPerformance's Avatar
Your Parts Guy
StreetLevelPerformance is on a distinguished road
Sure you have...it's a P.O.V
Old Mar 9, 2004
^^^ LMAO
Old Mar 10, 2004
INCivic's Avatar
any other feedback is welcome
Old Mar 12, 2004
HondaWhore's Avatar
HondaWhore is an unknown quantity at this point
Its my 2 cents, but what about nitrous. There only when you need it and less wear and tear because your not using it all the time. But if you use it all the time it can be harsh, just like high boost.
Old Mar 12, 2004
SpdRcrChk's Avatar
BOOST JUNKY
You're not always driving around "in boost" either.
But granted....the fact that it's (turbo) always there leads to temptation.
And n2o is only there when you need it, yes! But.....that's assuming you have a remote bottle opener. Say you're driving and ur bottle is closed and some rice-tard is trying you. Whatcha gon do?
"wait lemme pull over and open my bottle"
That sux. And I know it does, cuz well...as GREAT as n2o is...when I had it....lacking a remote bottle opener sucked in those instances.
Old Mar 13, 2004
sexcivic2k1's Avatar
i got my kit fs, check for sale forum
Old Mar 13, 2004
silverem2's Avatar
sexcivic2k1, why you sellin your kit?
Old Mar 15, 2004
ImPulse's Avatar
^ new car
