noob question regarding spool-up time
Old Mar 6, 2004
PeterV1228's Avatar
PeterV1228 is an unknown quantity at this point
I know that the turbo starts spooling at around 2500 rpms? and full boost at around 3500? I'm assuming this is in first gear, lets say you redline and shift to second, will you start the gear at full boost or does it still require 1000rpm spoolup time
Also, lets say your driving at a steady speed, then press the gas, will you get full boost or will it have to spool up?
Old Mar 6, 2004
SpdRcrChk's Avatar
BOOST JUNKY
SpdRcrChk is an unknown quantity at this point
If you're driving at a steady speed, and you punch it all of a sudden.....your turbo will need time to spool up. But, how quickly it does this depends on the size of the turbo.
If you're attempting to participate in a rolling race......naahhhh.....i'll just keep this one to myself.
Old Mar 6, 2004
MadWheel's Avatar
Premium Boosted Member
You should mention what kind of turbo you're referring to...
If you mean the SF setup T3 Garrett...
-In first gear you can floor it but you'll peel out before you make peak boost if it's set correctly.
If you're at 5000rpms with 0psi then floor it, lag will be almost non-existant, and spool up will be less than a second.
You can actually spool a T3 below 2000rpms (I used to) which is good for steady acceleration onto the highway.
My new turbo (T04B, clipped) needs some time, but at about 4000rpms it flys like a bat out of hell... All depends on what kind of driving you like.
For mid-range power and ocassional track use, A T25BB or ported T28 would be nice. A T3 super60 is great for track use with a lot of highway driving.
--My 2 cents...
Old Mar 6, 2004
PeterV1228's Avatar
It would be a T3
Old Mar 6, 2004
MadWheel's Avatar
Yeah T3 is a great turbo for our cars, perfect blend for daily driving and track use.
I reccomend the T3 Super 60, clipped...
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
Tedverseti
Apr 23, 2020 01:45 PM
jmdcivic
May 20, 2015 09:52 PM
Tarbris
Electrical
May 3, 2015 09:51 PM
