help finding a BOV
Old Mar 4, 2004
  #31
RiceBuRNeR's Avatar
Turbo Member
Originally posted by Alex1
so ur friends blow off valve makes that rattle snake sound right? pshhhchuchuchuchuch!!! yes?
Yes, its loud as **** under full boost when shifting too.
Old Mar 4, 2004
  #32
Alex1's Avatar
wait a minute, Blitz doesnt make the super sequential, HKS does. Blitz makes the super sound. Riceburner did u mean the super sound by Blitz?
Old Mar 4, 2004
  #33
Alex1's Avatar
can someone get a sound clip of this Blitz super sound?
Old Mar 4, 2004
  #34
Nodnero's Avatar
I think it depends on the company that made the wastegate and what type of opening it has. Some do make that "chuchuchu" sound. I need to ask my friend what model he has.
Old Mar 4, 2004
  #35
SpdRcrChk's Avatar
BOOST JUNKY
SpdRcrChk is an unknown quantity at this point
Wow! You guys need to do more research. Everyone here is wrong.
The "chchchchchchchchc" sound you guys are talking about is called COMPRESSOR SURGE. This is caused when the BOV doesn't open quick enough or enough at all to release the pressure in your charge pipes when the throttle is closed. The pressure in the charge pipes will cause your turbo to backspin. That "cool" sound you guys are talking about is the turbo wheel backspinning. It is harmful to your turbo but if you still want that sound, disconnect your BOV or get one with a hard spring or just tighten down the spring hard enough.
If you're willing to cause harm to your turbo for this sound, you shouldn't be turbocharged to begin with.
Old Mar 4, 2004
  #36
wannabeblown's Avatar
wannabeblown is an unknown quantity at this point
Its called turbo chatter. My s13 does it at a low rpm shifts. Its like a mild form of compressor surge. Compressor surge occurs at boost levels.
Edit: SpdRcrChk beat me to it.
Old Mar 4, 2004
  #37
RiceBuRNeR's Avatar
Turbo Member
Your right I meant HKS.....and that sound isnt compressor surge from the HKS BOV its the several chambers opening up in sequence, hince the name.
Old Mar 4, 2004
  #38
Alex1's Avatar
can someone get a sound clip of what turbo chatter sounds like.
so then why did that stock eclipse sound like that on the highway? could it be that he upgraded to a bigger turbo on stock stuff?
Old Mar 4, 2004
  #39
Alex1's Avatar
HKS super sequential is just a loud smooth whistle... i heard it.
opening in sequence? whats that mean?
Old Mar 4, 2004
  #40
RiceBuRNeR's Avatar
Turbo Member
^ he might have been running more boost than his stock BOV could handle.
Old Mar 4, 2004
  #41
Alex1's Avatar
i dont want to harm my turbo i just thought it sounded cool and its unique from all other BOV sounds a turbo car makes. i never knew it was caused by a compressor surge. thanks for the new info Yvette.
Old Mar 4, 2004
  #42
SpdRcrChk's Avatar
BOOST JUNKY
Sew your lips together so you can't go around handing out false information ever again.
Old Mar 4, 2004
  #43
Alex1's Avatar
whoa u guys are much more helpful than the norcal section.
now i got so much information i dunno which one is 100% correct.
so far im leaning towards the compressor surge theory, but keep the knowledge coming, i hope im not the only one learning from this.
Old Mar 4, 2004
  #44
RiceBuRNeR's Avatar
Turbo Member
Theres more than one chamber in the SSQV my friends makes a chachacha but I've never heard it whistle....atleast not like my Greddy type S. Hmm he might have his realy tight though so that it wont leak under full boost.
Old Mar 4, 2004
  #45
Actually, it is compressor surge. The HKS super sequential is very prone to causing compressor surge because it doesn't release the pressure all at once. The HKS SSQV sounds nice, and looks pretty, but its a perfect example of why pull-type BOVs aren't efficient at bleeding boost and saving turbos.
Old Mar 4, 2004
  #46
Alex1's Avatar
ok ok so far compressor surge is getting my vote... anyone else?
Old Mar 4, 2004
  #47
RiceBuRNeR's Avatar
Turbo Member
Attitude indeed...........
Old Mar 4, 2004
  #48
SpdRcrChk's Avatar
BOOST JUNKY
Do not listen to Riceburner. Seems like he has the RICER mentality.
Old Mar 4, 2004
  #49
RiceBuRNeR's Avatar
Turbo Member
Ill pass that on to my friend, man Im glad mine is a push/pull style.
Old Mar 4, 2004
  #50
Alex1's Avatar
so it is compressor surge right Yvette?
Old Mar 4, 2004
  #51
SpdRcrChk's Avatar
BOOST JUNKY
Yes Alex.
Old Mar 4, 2004
  #52
Alex1's Avatar
Yes Alex.
thanks!
Old Mar 4, 2004
  #53
Alex1's Avatar
hey u guys wanna post a sound just so we can all hear it? lol
Old Mar 4, 2004
  #54
SpdRcrChk's Avatar
BOOST JUNKY
anytime.
Old Mar 4, 2004
  #55
Boosted2k2's Avatar
Boosted2k2 should not be trustedBoosted2k2 should not be trusted
Yvette's right... the chchchchchchc is compressor surge. It's a mild form though. When my BOV broke (diaphram), i got it. Same sound as if you closed the outlet to the BOV, or the spring is over tightened.
Old Mar 4, 2004
  #56
RiceBuRNeR's Avatar
Turbo Member
Now your just being rude......Im not a ricer my SN is just a joke. If you took the time to read some of my other post and replys in other parts of the forums you would know that 90% of the time i know what Im talking about. I allready admitted I was wrong this time so drop it.
Old Mar 4, 2004
  #57
SpdRcrChk's Avatar
BOOST JUNKY
LoL relax man...just pushin ur buttons. I've read ur posts.
Guess I shoulda added a LoL or a
Old Mar 4, 2004
  #58
RiceBuRNeR's Avatar
Turbo Member
Im not trying to start a fight, but in my deffense click here: http://www.7thgencivic.com/forums/sh...ght=BOV+tuning
I just hate being called a ricer thats all.
Old Mar 4, 2004
  #59
Alex1's Avatar
RICER! lmao j/k
Old Mar 4, 2004
  #60
Alex1's Avatar
thanks, thats a useful post.
