IK20 or 22
Old Mar 1, 2004
Ahtasham's Avatar
Ahtasham is an unknown quantity at this point
IK20 or 22
Would Denso IK20 be better with Turbo setup or IK22?
Thanks!
Old Mar 1, 2004
CarbonFly's Avatar
Go with IK20
I think i saw someone who had IK16 at one point. I dunno.
Old Mar 1, 2004
StreetLevelPerformance's Avatar
Your Parts Guy
StreetLevelPerformance is on a distinguished road
Originally posted by CarbonFly
I dunno.
Beautiful. Why make a recommendation if you have no experience with either.
BTW bro I just ordered the IK-20 so I will let you know or just ask MadWheel.
Old Mar 1, 2004
CarbonFly's Avatar
Keep running your mouth dober. You might know a lot about engines but that doesn't mean you need to be an a$$ about it. You gave no more recommendation than I did.
I was telling him what most people go with. And I also stated the "I dunno" because I'm not sure why IK16 would be better than IK20. All I know is that the lower the number, the colder the plug.
Since you are claiming to be the god of everything D17, then why don't you enlighten us on the difference and what is better. It seems to be no problem for you to criticize others on this forum. Now its time for you to back up your bull$hit statements.
Old Mar 1, 2004
Ahtasham's Avatar
Hmmmm...... I thought it was opposite like IK22 being colder than IK20
Old Mar 1, 2004
Your Parts Guy
LOL. Read my post bro I said I would give him a review after I install them. I don't claim to know about them because I have no experience with them. Bottom line, you should've just refrained from clicking the reply button.
Old Mar 1, 2004
CarbonFly's Avatar
I told him the exact same thing you did, so maybe you shouldn't have been redundant.
I'll be installing my IK20's soon too. I'm gonna be installing it with my crank pulley. Granted I don't have the turbo yet, but that is coming.....lol
Old Mar 1, 2004
RiceBuRNeR's Avatar
Turbo Member
I saw a set of IK20's pre gapped for the 01 civic on ebay for like $49...is that a good deal?
Old Mar 1, 2004
civic01vtec's Avatar
can't lose with 22's
Old Mar 1, 2004
wrong
Old Mar 1, 2004
zinkyroo's Avatar
cool beans
zinkyroo is an unknown quantity at this point
dober is not an *** at all. He was clearly correcting your comment with relevant information, so he would not make the wrong choice on sparkplugs. Also why do you keep locking threads about problems with SF? I guess its fair since maxrev only had 1 problem to let that thread become over 20 pages, but yet when someone speaks out against SF its just fine and dandy to lock the thread.
Old Mar 1, 2004
were they used ?
if they are brand new and it is $48 shipped, then yes. Dezod has them for i think $12 a piece.
Old Mar 1, 2004
Your Parts Guy
Thanks Zinkyroo. I wondered the same thing about those threads? He is out to get me anyways because he is "butt hurt" over some comments I made that really must've hit home.
Old Mar 1, 2004
zinkyroo's Avatar
cool beans
Yeah hes tough online
Old Mar 1, 2004
civicskater's Avatar
Chicks dig my scent
****, back to the topic
id go with IK20s, i have them now and have no problem what so ever
Old Mar 1, 2004
^^^ yeah, but ur not boosted
Old Mar 1, 2004
Chicks dig my scent
true..but i will be a month...so we'll see how it runs with the turbo i dont think it will be any worse at all, probably better
Old Mar 1, 2004
well, if you are just cruising around town, the the 20's will be ideal, if you are always on the throttle, then 22's will be better.
Old Mar 1, 2004
mlovela's Avatar
mlovela is an unknown quantity at this point
I got the IK20's for only 39.95 from the following vender off of ebay. Price included S&H.
allsparkplugs
Figured i would share the deal!
Old Mar 1, 2004
MadWheel's Avatar
Premium Boosted Member
Well either way I know Dezod bought a TON and sold almost all but may have some left. That'll ship a little bit faster.
Besides saying "wrong" about the heat ranges, please let them know why.
Ik16s are stock temp ratings. IK20s are fine for our 10psi or less setups. 22s are better for higher psi and built motors. Also, all iridium plugs for our cars come pre-gapped.
Iridiums dont last as long as platinum but do perform better so it's a tossup.
I just switched from NGK Iridium IXs to Denso Iridium IK20s and they perform almost the same, hopfully the Densos last longer, though I did notice a slightly smoother idle with the Densos.
Old Mar 1, 2004
i said fly was "wrong" about which #'s mean colder
Old Mar 1, 2004
MadWheel's Avatar
ahh cool, sorry bro...
Old Mar 2, 2004
ok, here is the general jist of it......the best way i can explain it.
There are many factors that determine which plugs are better. Just b/c someone use's 22's doesn't mean they are better for your setup. Altitude, octane of gas, mods, and driving help determine which is best for your car.
Higher elevations mean less oxygen and colder running, therefore a hotter plug is required. Lower elevations is the opposite, meaning a colder plug is needed. The octane of gas is very important too. If you use a low grade fuel then you will need colder plugs to prevent detonation. Also, the way u drive plays a key role. If you are just cruising around alot and on the throttle once in a while then a hotter plug is needed. If you are racing alot on the track or street then a colder plug is needed.
Also, iridium plugs are required for turbo applications b/c they are a "resistorless" plug. A non-resistor plug requires less voltage which allows the plug to fire under extreme combustion conditions.
I read somewhere that Denso recommends changing thier irdium plugs after 30,000 miles and NGK recommends changing them at 60,000. But that also depends on how hard u drive ur car.
If you put too cold of a plug in then you may experience problems starting and/or fouling your plugs because "fouling" deposits won't be burned off b4 they cause damage. If you go with a hotter plug, it may cause overheating, denoation, and possible damage to the plug and combustion chambers.
All in all.........i suggest going with the 20's. Inspect your plugs regularly and check for detonation.
Old Mar 2, 2004
MadWheel's Avatar
I have 20s, and no more random CEL lights under cold starts (runnin rich and misfiring) that i had with my ngks
Old Mar 2, 2004
hondacivicd17's Avatar
hondacivicd17 is an unknown quantity at this point
what about with nitrous? What plugs should i use with nitrous?
Old Mar 3, 2004
guns's Avatar
Skyline R33
guns is an unknown quantity at this point
I dropped in IK24's last night.
Off boost, idle and starting is just fine. Spraying methanol will keep them clean, even if I run too rich. I am at or below see level and plan on cranking up the boost.
I went with two ranges colder. I did that because I figure why pay $50 to avoid some detonation and just go a little colder. Maybe w/o the meth I would say they will foul out. But with meth I think they will stay very clean.
please feel free to comment. I dont claim to know anything. So fire away.
Old Mar 3, 2004
^^^ just make sure to check ur plugs for built up deposits.
Old Mar 3, 2004
depends on what size jet u are running. I say stick with stock unless u are using a 75 shot, then i suggest going one range colder. Never use platinum tiped plugs cuz they tend to foul easily with spray. I have also heard that splitfire plugs and n2o don't mix.
Old Jul 21, 2004
Speedracer32's Avatar
Speedracer32 is an unknown quantity at this point
Ok..i picked up some IK20's today and was just making sure i bought hte right ones
I got them for 12.99 eash at Autozone.
Just to make sure, the gap is 44 right???
and bump for future questions
Old Jul 21, 2004
KnocturnalEM2's Avatar
I am your Mom's Hero!!
^^Dont adjust the gap on Iridium plugs...they are preset!!!
