if you had $1k....
Old Feb 22, 2004
EnProceso's Avatar
if you had $1k....
how would you spend it? i'm looking to build up the motor for boost and have a little over $1k to spend on it but i'm wondering what i should start with? what is our engines weakest link.....like what would be the first thing to break under boost. at first i was thinking pistons and rods but it seems they can handle 10psi on a daily basis so i'm thinking perhaps sleeve the block or maybe a PnP head. i need some opinions, so let me know what you guys think! what would you buy and why?
Old Feb 22, 2004
jwcardy's Avatar
SRT-4 owner with 2MCHPSI
jwcardy is on a distinguished road
boost is addicting....yes our blocks, piston, and rods can handle 10psi but isnt recommended all the time.....under normal drivin how much would you actually hit 10psi....what i am going to do with my money, is build the block to handle more boost.....well dhracing is doing that....but yeah...start out with the simple stuff so that you dont have down time like pnp head from dh, crank pulley, CLUTCH, flywheel... stuff that you can bolt on and dont have to have a couple days down time, like you would with pistons and rods, rings and the others....it you can get by with the down time i would go with the pistons and rods, blockgaurd and sleeves first though..... that will let you boost more, providin you can get the fuel correct....
Old Feb 22, 2004
StreetLevelPerformance's Avatar
Your Parts Guy
StreetLevelPerformance is on a distinguished road
our rods are puny
Old Feb 23, 2004
dragoon's Avatar
i'd buy a clutch, convert my fuel system to return, a greddy emanage, and several hours of professional tuning.
Old Feb 23, 2004
Speedracer32's Avatar
Speedracer32 is an unknown quantity at this point
yeh i would do clutch and flywheel and probably a Apex-i V/SAFC depending on what type of fuel delievery setup our going to be doing
Old Feb 23, 2004
CivicMexicano's Avatar
El Pinche Turbo Mexicano
CivicMexicano is an unknown quantity at this point
well since i think he has an atuo, the flywheel and clutch is out, any other suggestions....
Old Feb 23, 2004
C2i0v0i1C's Avatar
SuperMODrizd
save more, u cant build the block pistons rods sleeves for 1k, unless u install it yourself and have friends in the business that can get things for wholesale
converting to a return, is doable under1k, but why
Old Feb 23, 2004
Catalyst's Avatar
Catalyst is just really niceCatalyst is just really niceCatalyst is just really niceCatalyst is just really nice
you can get the block sleeved for about $700. But then theres the labor for removing the engine, and then putting it back in. i would say buy an extra motor so you can build it up in the future without having a lot of downtime on your car.
Old Feb 23, 2004
well in that case
do a tranny swap ...
Old Feb 23, 2004
civic01vtec's Avatar
save your money steve......the best thing to do is to sleeve the block, but if u do that u might as well build the whole bottom end. If you wanna spend $1k, i say build up ur tranny.
Old Feb 24, 2004
EnProceso's Avatar
already bought a TCI overhaul kit, just need a donor torque converter to send to level ten.
as for buying a whole new engine, that isnt really a option, i live in an apartment and dont have a place to keep it. so i'm gonna buy all this internal stuff and take some time off work and have it all installed at once.
Old Feb 24, 2004
seijin_av's Avatar
seijin_av is an unknown quantity at this point
just leave the engine block in your apartment =) like on a free desk, or the next to you in the bed, an empty sink, or if you really have to, on the ground. ooorrr you could get creative and build some kinda stand to hold it. unless they sell those. or maybe you could even drill holes in your ceiling and hang the engine. idk just some suggestions. i'm a bit buzzed.
Old Feb 24, 2004
icebergslim's Avatar
BOOSTED HYBRID
icebergslim is an unknown quantity at this point
I'd sleeve the block.
Old Feb 24, 2004
RiceBuRNeR's Avatar
Turbo Member
If I had $1,000 Id put it back in my bank account. My DH Head/custom intake manifold/Cam/TB cost me all the money I had....Not to mention the custom turbo manifold from SF......oh well all worth it to have one of the fastest 7th gens around.
