If your looking for bigger injectors........
Old Feb 20, 2004
HTOWNBOY's Avatar
HTOWNBOY is an unknown quantity at this point
Just want you all to know that if your looking for bigger injectors to use that will fit our cars. You can get em off a VW Passat 1.8T. I think they are rated at 310cc or 330cc. I am using them on my car. I have my boost set at 8psi and it works very well with my SAFC.
Later,
Alex
Old Feb 20, 2004
AZNRACR's Avatar
cool dude, thanks for the FYI. Someday when i'm boosted, i'll appreciate it even more.
Mike
Old Feb 20, 2004
RiceBuRNeR's Avatar
Turbo Member
lol thats funny b/c 2 years ago my GF totaled her passatt.....damnit I wonder if its still in the junkyard?
Old Feb 20, 2004
UnOrthodox9546's Avatar
UnOrthodox9546 is an unknown quantity at this point
do you know what year passat?
Old Feb 20, 2004
Speedracer32's Avatar
Speedracer32 is an unknown quantity at this point
direct fit into the manifold with no modication??
and did you have to adjust the clips??
Old Feb 20, 2004
HTOWNBOY's Avatar
mine are off a 2000
Old Feb 20, 2004
RiceBuRNeR's Avatar
Turbo Member
^ and did they drop right in w/ no mods? BTW how many CC's can our stock ones flow.
Old Feb 20, 2004
HTOWNBOY's Avatar
all you have to do is pull off your old injectors and put in the new ones with out the clip.
you will also need to take off the studs that hold the fuel rail and get longer bolts and 2 spacers to hold down the fuel rail. oh, make sure you take off the injector harness from the passat too. the injector harness on our vics will not fit the passat injectors. I will post some pics of the injectors asap.
Old Feb 20, 2004
coo
Old Feb 21, 2004
truehonda's Avatar
truehonda has a spectacular aura abouttruehonda has a spectacular aura about
very cool, and SF will be offering a fuel rail soon, so there may be more possiblities. But really how much can stockers hold out to?
Old Feb 21, 2004
opto_isolator's Avatar
Sounds like more hassle than its worth! I'm working with Venom Performance for larger (custom flow rate) injectors. Its taking them a while, because they didn't know about the injectors being different from previous gen civics - but once things work out I'll see about getting a P/N from them. That way, the injectors will be a direct fit with no fuel rail or harness modifications......
Old Feb 21, 2004
HyaBoosta's Avatar
so are there any aftermarket injectors that we can just drop in other than venom. and by just upgrading the injectors and adding a fuel managment system (safc or emanage) be able to boost? or will there need to be an addition of a vortec FMU
Mr.Beefy
Aug 12, 2015 04:39 PM
wootah88
Jul 21, 2015 10:22 AM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
strokelessone
Feb 4, 2002 05:01 AM
wawacito
Dec 14, 2001 08:52 PM
