hasport update
Old Feb 2, 2004
chrisgushue's Avatar
Bring Hockey Back!
chrisgushue is an unknown quantity at this point
hasport update
just received good news form hasport, the k20a3 from a rsx will fit in a 2002 civic coupewithout having to change the manifold(says on there website only the si will) and with there orignal k series mounts
Old Feb 2, 2004
showoner's Avatar
showoner is an unknown quantity at this point
yeah! HASPORT - YEah !.....hey lady .....yeah....
we dont have to change the mounts,....yeah !....uh oh...
i went poo!.......Yeah ! yeah !.....
Old Feb 2, 2004
briang's Avatar
briang is an unknown quantity at this point
Who said that?
Old Feb 2, 2004
Bring Hockey Back!
the info person form your website
Old Feb 2, 2004
Bring Hockey Back!
Report Junk E-Mail
Report and Block Sender
Sent : February 2, 2004 3:44:57 PM
To : "Chris G" <hockeyguy77@hotmail.com>
Subject : Re: k20 swap into civic 2x coupe
| | | Inbox
Ignore what the site says. Did some inquiring today, they all will fit fine.
(as in all manifolds, all k series engines)
----- Original Message -----
To: <info@hasport.com>
Sent: Monday, February 02, 2004 3:31 PM
Subject: Re: k20 swap into civic 2x coupe
Old Feb 3, 2004
Hawk's Avatar
You boost, I-VTEC
uh oh conflicting theories...
I'd trust Brian G, he's all knowing
Old Feb 3, 2004
Bring Hockey Back!
well can brian g pls confirm this cuz i kinda need to know soon and hope someone isnt bsing me form hasport
Old Feb 3, 2004
CivicMexicano's Avatar
El Pinche Turbo Mexicano
CivicMexicano is an unknown quantity at this point
i emailed Hasport also but, about the k24 swap and
they said it was the same Mount kit??
Old Feb 3, 2004
Bring Hockey Back!
will someone from hasport let me know?
Old Feb 3, 2004
ViNRoCk8's Avatar
#1 S2000 Fan
I thought it was the same except for one mount.
Old Feb 4, 2004
briang's Avatar
I'll straighten them out, but the K24 does not fit with our current ESK1 kit. The new kit which features a new right-hand mount for the K24 will be out in the next month or two. The larger manifold found on the K24 and base model RSX interferes with the radiator on the Civic.
brian g
Old Feb 5, 2004
Bring Hockey Back!
dammit now i wish i didnt buy the engine, i guess it wont be that hard to fabricate
Old Feb 5, 2004
Hawk's Avatar
You boost, I-VTEC
just put a SI intake manifold on your rsx k20a3, that should solve your clearance issuses.
Old Feb 5, 2004
Bring Hockey Back!
or just turbo it right away, that should work lol
Old Feb 5, 2004
Hawk's Avatar
You boost, I-VTEC
turboing it won't help your clearance issue
Old Feb 5, 2004
Kloverz's Avatar
Kloverz has a little shameless behaviour in the past
Man cant wait till it comes out next month time for my setup thats some good new there,
Old Feb 5, 2004
brian g
would it fit with a Si raditor instead of the original??
Old Feb 5, 2004
atl01's Avatar
this has been an atl01 production..
atl01 will become famous soon enough
hey chrisgushe, im going through the same thing that you are with the K20A3 not fitting into the civic. I talked to someone at hasport about a week ago and they said that it will fit but some trimming needs to been done around the core support. As far as the intake manifold working off the Si, i doubt it because the A3 uses a intake with 2 different length runners, which change at different rpm's similar to the GSR IM. And the si uses a straight through runner design. Check it out at www.hondata.com under the K-serries tech article. Also compare the two manifolds at www.hondaautomotiveparts.com (Si manifold), www.acuraautomotiveparts.org (RSX manifold) the two look nothing alike. let me know what your going to do about this problem, maybe it will help me to. Im just thinking about taking it the the speed shop and let them deal with it.
Old Feb 5, 2004
briang's Avatar
The RSX type S and the Civic Si intake manifolds are identical in measurement. They are interchangeable. The Type R has slightly more volumn on the runners and probably the plenum too. But, it will work with our kit.
After we come out with the K24 bolt in kit and you people get ready to buy the K24s, make sure they are CRV K24s so that you can bolt on the Si or RSX Type intake manifolds.
brian g
Old Feb 5, 2004
Bring Hockey Back!
well can u make sur eppl at your company know wtf theyre doing? so i dont get "assured" information that is completly false
Old Feb 5, 2004
Bring Hockey Back!
sorry to sound mad but when im told it will fit with no modification and now i need to find a manifold in canada to fit it kinda pisses me off
Old Feb 6, 2004
brian g
i found a cheap acord engine, could i use a k20 head instead.....
and what the diference betwwen the accord one and the CR-V one, besides compresion...
UltraHDGames
Jun 8, 2016 05:16 PM
Dave Brabant
20
Oct 6, 2015 12:44 AM
Jrosa
Sep 14, 2015 08:24 PM
shaejb15
Sep 3, 2015 01:35 PM
naokigoffi
Aug 30, 2015 06:19 PM
