SF fuel system with bigger injectors?
Old Jan 20, 2004
hondacivicd17's Avatar
hondacivicd17 is an unknown quantity at this point
If you use the SF fuel system with bigger injectors will you be able to run higher boost without using alcohol injection?
Old Jan 20, 2004
C2i0v0i1C's Avatar
SuperMODrizd
i dotn think the stock internals can handle that even though u have bigger inj.
Old Jan 20, 2004
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
alcohol inj. has nothing to do with the amount of fuel coming in ... its purpose is to raise the octane level
Old Jan 20, 2004
Andrick's Avatar
Andrick is an unknown quantity at this point
And to reduce combustion chamber temp.
Old Jan 20, 2004
i know about alcohol injection, im just saying i dont want to use it for 9-10 psi, im doing my internals i was just wondering if with bigger injectors, and the SF fuel system if it would be enough to handle 9-12 psi without alchohol injection
Old Jan 20, 2004
Jodster's Avatar
Post Whore General
The SF fuel system is designed to run up to 12psi on stock injectors, so it should be fine with bigger injectors.
Old Jan 20, 2004
opto_isolator's Avatar
The injectors have nothing to do with it. If you run that much boost without alcohol injection you'll run into detonation. The only other way to prevent this is to retard the timing. The only way to retard the timing is the E-manage......
So unless you want to shell out another $300+ stick with the setup you've got.....
Old Jan 21, 2004
Catalyst's Avatar
Catalyst is just really niceCatalyst is just really niceCatalyst is just really niceCatalyst is just really nice
We can calibrate the fuel system to do whatever you want. You just have to let us know ahead of time. If you take the normal system and put 550 cc injectors on it, you will run WAY rich. we have to calibrate it to run correctly.
Old Jan 21, 2004
Is it possible to later send the system back to you and have recalibrated?
Old Jan 22, 2004
Catalyst's Avatar
yes
vtecbrah
May 31, 2015 01:24 PM
Trav_02civic
Engine start problems
Apr 23, 2015 08:57 AM
htowncivicEX
Jan 21, 2002 11:48 AM
TaiChi
Dec 17, 2001 09:09 PM
