Maxrev fuel system?
Maxrev fuel system?
How is Maxrev's ERL-FM2 fuel system? How does it compare to SF's fuel system. How hard would the install and tuning be on this system?
i dont think anyone on here has that specific system,
ZINKYROO, has/had the maxrev kit but i dont know if he had the fuel kit ur refering too
Originally posted by zinkyroo
get a return line, aem ems, and 4 550cc injectors
Cheapest way is to boost your fuel pressure up.
The way fuel injectors work is they have 2 pulses where the electric signal that is sent to them cuts off. When the signal is cut the injector opens and sprays the fuel. You can actually boost fuel pressure up to the point where the pulses on the injector are pretty much constant and you move a lot more fuel. If that still isn't enough fuel then you would need to step up to some 550 cc injectors.
My experience with SR20 motors, we can get 278 Hp with the stock turbo and injector buy boosting fuel pressure up. Stock HP is 205.
vtecbrah
May 31, 2015 01:24 PM
