removing oil pan helpp
Old Jan 14, 2004
Speedracer32's Avatar
Speedracer32 is an unknown quantity at this point
Unhappy removing oil pan helpp
i got all the bolts out but it's still not coming off
those of you have installed your own turbo's
any hints or ideas???
almost done wit install so any answers would be appreciated
thanx peoples
~Marcus
Old Jan 14, 2004
no one
Old Jan 14, 2004
keepin_it_clean's Avatar
keepin_it_clean is an unknown quantity at this point
check to see if catalyst or boostedciviczex are online, i know there is a diy for the install on here somewhere ill try to find it for you
Old Jan 14, 2004
Oil lines
Ok, first of all, you have to remove your oil pan. All you have to do to do this is....
drain all of your oil, remove all of the bolts/nuts from around your oil pan, and use a flathead screwdriver and gently pry the pan away from the block.
now that your pan is out of the car, drill the hole with the drill bit that matches the size of the oil drain line. Now, take it to a welder (of it you can weld) and have the drain line welded into place. Re-install your oil pan, and use the aeroquip line to hook the drain line from the turbo to the drain line on the pan.
Here is the mark where you have to drill
diy - http://www.7thgencivic.com/forums/sh...ight=turbo+diy
pic of oil pan a little more than half way down...
Old Jan 14, 2004
civic01vtec's Avatar
just pry it off man
Old Jan 14, 2004
lucky13matt's Avatar
lucky13matt is an unknown quantity at this point
just beat the dang thang off
Old Jan 14, 2004
aight ima keep trying for now
thanx for the responses
Old Jan 14, 2004
sexcivic2k1's Avatar
kick it off! jk, i told u waht to do.
oh, dont drill that hole in the wrong location! be careful where you drill!!!!!!!!!!!!!!!!!!
Old Jan 14, 2004
StreetLevelPerformance's Avatar
Your Parts Guy
StreetLevelPerformance is on a distinguished road
same here just bang on the damn thing with a hammer but make sure you dont dent the pan too much...it will eventually loosen dont worry.
Old Jan 14, 2004
MadWheel's Avatar
Premium Boosted Member
forget banging... use a pry bar. go to the driver side of the car, you can see a lip that sticks out off the pan. wedge the bar between the lip and the metal above it. spent a whole night and broke 2 screwdrivers (gently pry it off my a**!). using the pry bar it took all but 5 minutes. hopfully you have it off by now. suggestion, use red silicone sealant before u put the pan back on. scrape off all the old crap off the pan and reseal with the red silicone. you won't ever have to worry about an oil leak... i had a leak, did the silicone thing, not a drop since! plus it's only like 4 bucks for all you need (pep boys or auto zone)
Old Jan 15, 2004
bac7213's Avatar
bac7213 is an unknown quantity at this point
yo thsi is teh easiest way i didnt even use a ****ing pry bar so i bougth it for nothing, well, stand in front of teh car, make sure u took all the bolts off the shift linkage, and all that ****, well stand in front, now turn ur car wheel, to the left, all the way left, ok now go back to the front, and get on ur knees, u see u will be able to see the oil pan if u bend down by the tire, since the tire is turned all the way, well take a good heavy duty flat head screw driver, and a hammer, n rigth on teh corner of the oil pan there should be like a space to wedge the flat head in well put it there and hit it with the hammer, make it go in, in between the crack of teh engine and oil pan, well hit it and hit it, and when the flat head is in then pry it off man, pops rigth down, mad easy
Old Jan 15, 2004
bac7213's Avatar
lol lol oooo **** i didnt even notice but madwheel gave teh same advice lol, thats hot
Old Jan 15, 2004
thanks fellas for the quick responses
we got it off last night.
Old Jan 15, 2004
MadWheel's Avatar
good news then lol
it's all good
Old Jan 15, 2004
did u get it installed yet ?
Old Jan 15, 2004
yeh
crankinit up tomorrow after gasket sealent dries and i put the oil in
Old Jan 15, 2004
MadWheel's Avatar
sweet let us know how it goes
Vaguexo
Jun 13, 2015 04:11 AM
jmdcivic
May 20, 2015 09:52 PM
BootyDo
May 7, 2015 04:46 PM
leon1
Apr 28, 2015 07:32 PM
Grey
16
Jan 27, 2002 11:34 PM
