Hellllppp
Old Jan 8, 2004
bac7213's Avatar
bac7213 is an unknown quantity at this point
Hellllppp
aigth i got my SF kit but the porblem i see is that my fuel system didnt come with wires, well i see a positive terminal, a negative terminal, and no terminal for teh green wire (signal), what do i have to do, do i connect a red wire and a green wire to the positive and ground the negative or what???? let me know what i have to do thanxs
Old Jan 8, 2004
andyman97's Avatar
Turbo Guru
Terminal on top should go to a positive lead. Terminal on the side should go to a ground source.
Old Jan 8, 2004
bac7213's Avatar
what about the signal wire i dont have a signal wire, i just have 2 terminals, just a positive n negative , i have no green wire and no signal terminal
Old Jan 8, 2004
andyman97's Avatar
Turbo Guru
Hmm, check with SF, not sure if you're fuel system is the same as mine.
Old Jan 8, 2004
andyman97's Avatar
Turbo Guru
I take that back. You'd better pm catalyst or catch him online. Mike Stafford's phone isn't in service anymore.....
