Engine Swap, Pls Help!!!
Old Jan 3, 2004
pnoyster2k1cvic's Avatar
Balut Eating Champ
Question Engine Swap, Pls Help!!!
I wanted to buy an engine online, but i'm a noobie when it comes to this , it seems like all their engines are complete, and the best price and what not, my question is, what do I need to have a smooth engine swap with out buying any additional part for $1000+ or somethin to get it complete.
H22a Engine Swap 92-95
If I miss anything pls let me know...
- Hydraulic Tranny
- ECU (P13)
- Alternator
- Starter
- Clutch
- Flywheel
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Engine Harness
- Sensors
- LSD Tranny
- Hasport Engine Mounts
If you guys know any site that sells less than 20bills shipped for a complete h22a or other 200+HP engine usdm/jdm engine PLS let me know Thanks!
Old Jan 3, 2004
Anotherslo1's Avatar
Anotherslo1 is an unknown quantity at this point
Wel if your putting a 92-95 H22a into a US spec car 96 and up, your gonna need an obd1 to obd2 wire harness. Unless you change the 96 up car into obd1.
Old Jan 3, 2004
NoBottleJustThrottle's Avatar
NoBottleJustThrottle is an unknown quantity at this point
i dont know much about that particular swap...but from other swaps you should look into:
axles
radiator (if you can use stock with fans)
custom hoses needed
shifter cables
shifter assembly
throttle cable
intake (i believe an integra type R 3" CAI works with that swap)
it would be a good idea to change the belts on whichever motor you get too, its just a fairly cheap saftey measure
Old Jan 3, 2004
Balut Eating Champ
Very good pointers, I make sure I have these in mind... Thanks!
RicoSuave
May 20, 2015 01:57 AM
cloudguy
Apr 28, 2015 05:02 AM
shawe90
Apr 14, 2015 07:10 PM
robbclark1
Dec 12, 2001 12:18 PM
supercivic01
South
Nov 30, 2001 11:27 AM
