SF Kit question about sizing of turbo feed and return oil lines...
Old Dec 28, 2003
opto_isolator's Avatar
For those of you who have the SF Kit, does anyone know what size the fittings are for the oil line that comes with SF's kit? Specifically are they AN size fittings (-6AN) or are they standard NPT fittings (1/8")? I know from the pictures that it appears that the top of the turbo has a AN to 1/8" NPT fitting, but I am not sure of the size. And I am not sure what the back looks like (where it connects up to the oil pressure switch). I am going to order the Golden Eagle VTEC sandwich plate, which will make installation of the oil lines easier and neater (plus allow me to easily install my oil pressure sending unit as well), but you can specify which fitting you want to order it with - which is why I need to know this...I've tried to PM catalyst, but his box is full, and I haven't had any replies from the last PM which I sent him. If anyone knows, please clue me in, thanks.
Old Dec 28, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
the inlet to the turbo is a 1/8npt .. the fitting to the ss line is a 4AN.
Old Dec 28, 2003
Ok - thanks for that info. How does SF connect the line to the pressure switch at the back? Is there a 4AN to 1/8" NPT fitting included, with a male/female/female tee? I'm trying to prepare for it, so that I don't need to buy any additional hardware......
Old Dec 28, 2003
wannabeblown's Avatar
wannabeblown is an unknown quantity at this point
probably bspt. If you thread ntp into the oil sensor hole it will cause problems.
Old Dec 28, 2003
Catalyst's Avatar
Catalyst is just really niceCatalyst is just really niceCatalyst is just really niceCatalyst is just really nice
the oil line kit comes with everything. Since the pressure sender on the back is not a standard thread (1/8" BSP) we include everything you need.
Old Dec 29, 2003
Don't mean to be an ***, but that's not the answer to my question.....
Tedverseti
Apr 23, 2020 01:45 PM
RIPSAW
Nov 6, 2015 04:36 AM
