For those of you with custom fuel injectors.....
Since no one likes to answer PM's - I'll post here, for everyone to see.
I've read that some of you have RC engineering injectors. But, RC says they will not fit properly due to the fact that they are longer than the stock ones.
Venom - well, Venom says there are many different injector styles based on the harness.
So - who here can clear up EXACTLY what injectors they used (P/N's would be helpful) - so that the rest of us can put our return fuel systems together.....
Thanks....
Thanks....
Part number...sorry.
So, can you elaborate what you did to make them fit? When I talked to RC a while back, they said that they did not have anything available for our car, and that the older style would not fit (too long).
How exactly did you get them to work. Also, did you have a customized fuel rail (welded bulkhead connection on the opposite end, similar to Boosted's)?
bare with me bc i didnt do it, i had a shop do it, i think they used some kinda rubber spacers and possibly longer bolts at the two ends to compensate for the length, also by doing that u run into a prob with the TPS, it sits between the rail and the TB i think, had to kinda shave it down maybe and maneuver it so that it still fit there
GritzNGravy
Aug 19, 2015 03:03 AM
Green02civic
Jul 27, 2015 10:48 PM
LorenzoC0395
Jul 14, 2015 08:46 PM
mistermenphis22
Jul 13, 2015 04:43 PM
