blowing up engine
Old Nov 5, 2003
CivicRacer5's Avatar
CivicRacer5 is an unknown quantity at this point
blowing up engine
It seems there are more and more people messing up their motors with the SF turbo kit, just wondering what was happening, if these people could reply and give some details!
Old Nov 5, 2003
cambo's Avatar
I wish I was asian
huh? never heard of anyone blowing their engine w. the SF turbo yet.
Old Nov 5, 2003
civic01vtec's Avatar
i never heard of this either.......what are u talking about ? I have heard nothing but good about the SF kit.
Old Nov 5, 2003
robbusaf, andyman, and didnt catalyst have something go wrong
Old Nov 5, 2003
trust me im not dissing SF there the best thing that has ever happend to 7thgen civics, and i am purchasing a kit soon, i just would like to know of all the problems people have had so i can prevent something happening to me
Old Nov 5, 2003
the only problem i can think of is running too lean
Old Nov 5, 2003
but that is only once in a while
Old Nov 5, 2003
Catalystsgrl's Avatar
Catalystsgrl is an unknown quantity at this point
since you are not trying to diss SF then can you please rename your post so people dont get pissed off or something.. thanks.
Old Nov 5, 2003
kjgracing's Avatar
Hail to the king baby
kjgracing will become famous soon enoughkjgracing will become famous soon enough
I'm sure if you boost over 9 and don't have a block guard or lower compression pistions...something has gotta pop
Old Nov 5, 2003
CarbonFly's Avatar
What happened to their engines wasn't the fault of the SF turbo system. It was their own fault for boosting too much power. SF can't be held responsible for the actions of the turbo owner. It's not like a part on the SF turbo broke or something. The turbo owners willingly turned up the boost and broke their own $hit.
Old Nov 5, 2003
Jodster's Avatar
Post Whore General
RoBBUsaF hit a spike boost of 18psi due to his ghetto rigged boost controller. andyman97 had some loose connections I think. And Catalyst designs and builds the parts. None of it is due to the SF kit at all. Its all due to mistakes and finding the limits of the motor.
Old Nov 5, 2003
alright thanks for clearing everything up.
Old Nov 5, 2003
name changed so no one gets pissed
Old Nov 5, 2003
opto_isolator's Avatar
Its all about tuning.....if your car isn't tuned its going to pop. If you read up on the physics of boosting you'll see that the higher you boost the further along the ECU tries to advance the timing. To compensate SF has alcohol injection. Its sort of a cheap (but effective) way to fix the problem. The real way to fix it would be to tune with an aftermarket ECU such as the E-manage or EMS - but those are expensive.
You also have to remember that SF's kit was pretty much designed around cat's car - which means that it was tuned for cat's car. The fuel system is fairly generic, which means that it will work well at mid to low boost, but when you start pushing boost you'll need to fine tune it to prevent from running lean, etc.....
So, that is pretty much the reason people are blowing **** up - they're pushing things too much.
Tune it properly to run at a decent boost level and you (in theory) shouldn't have any problems....
Old Nov 5, 2003
andyman97's Avatar
Turbo Guru
The egt probe was never hooked up so after the install it was tucked away behind the battery which to no surprise came loose and caught the radiator fan, overheating the engine and blowing a headgasket.
I was running too rich in the higher rpms. It wasn't "too much boost, it was a matter of being careless. I will be swapping in a slightly used engine with only 14k miles on it that I paid 500 shipped for and I'll be doing that this weekend.
As far as SF goes, I don't blame those guys, it could have happened to anyone, it was just a human error and it's all good. Mike has done nothing but try to help me out since I've had issues.
Old Nov 5, 2003
detoX's Avatar
detoX is an unknown quantity at this point
ok, so the alcohol injection doesnt do much? cause thats whats its for ryt? to not go lean at 9-11 psi?
Old Nov 5, 2003
Old Nov 5, 2003
Thank you
Old Nov 6, 2003
corbeaucivic2nr's Avatar
corbeaucivic2nr is an unknown quantity at this point
so with blockguards pistons and rods, what the most anyone cranked up the boost to and had succesful runs at the track or street, and was able to drive it home, then to the store and back the next day?
Old Nov 6, 2003
andyman97's Avatar
Turbo Guru
I don't think there is anyone that has fully built the bottom end on a d17 yet is the thing.
Old Nov 6, 2003
futurersxswap's Avatar
Passin' You On 19's.....!
futurersxswap is an unknown quantity at this point
im still on BONE stock motor... with 9psi daily driven... made about 15 total runs at the track so far... NO problems other than my own dumb move with the map sensor valve... i put it in wrong at the start.. i HATE to see people doubting and downing on this kit!!!! this is THE BEST kit out there for our cars, possibly the best SOHC kit ever made for a honda! just look at the power numbers and the track times... SF is GOD.. to hell with the haters..
p.s. ive seen the TD kit in person.,.,. if ANYONE doubts SF quality, look at that kit.. thats what a ghetto kit looks like ... SF = VERY PREOFESSIONAL, VERY CLEEEEEEEAN, as long as i do the install.. LMAO
Old Nov 6, 2003
Green Civic's Avatar
The highest boost is like 9-11 psi.
Old Nov 6, 2003
Big Baller L's Avatar
Nugget Garage Since 2004
even tho i have never seen this kit in person, or been in a car that is turbo, i still belive it! I dont know why...but 13's is an acomplishment that is hard to belive, but has been done! Eveyone i tell about the kit and what numbers it puts dont tell me its bullshit....we need a solid video to proove them wrong. Cant wait for my kit!!
Old Nov 6, 2003
hey man im not hating on the SF kit, im buying the thing for god sakes i was just simply asking what had gone wrong with the peoples motors, so i wouldnt make the same mistake
Old Nov 6, 2003
^^agreed
Old Nov 6, 2003
chesireCAT's Avatar
chesireCAT is an unknown quantity at this point
Andyman.....what is the egt probe?
Brandon
Old Nov 6, 2003
egt = exhaust gas temperature.. measures just what it says.. LOL... i will get video.. but i cant cause i have no digi cam.. maybe if i can find someone.. or bring my guy to track with me.. it will be all good.. but TRUST m,e... CONSISTENT high 13s.... and with a good 60' tim e (better tires).. i would be around 13.5
Old Nov 7, 2003
Catalyst's Avatar
Catalyst is just really niceCatalyst is just really niceCatalyst is just really niceCatalyst is just really nice
The boost isnt what destroys your engine. It is the tuning. I put some good gas in, and had a new prototype of the alcohol injection in it. I ran 18 psi and lived to tell. I knew that was way beyond the limits of the motor, but i did it on accident. I was running 15 psi with that alcohol injection setup. But that isnt the normal one, it is way expensive, and is not available to the general public because it is too much of a pain for us to make.
Old Nov 8, 2003
rscivic's Avatar
rscivic is an unknown quantity at this point
8psi daily, 184hp, 189torque and as of last night, got up to 143mph- running almost dead even with my husband in his supercharged v6 accord. I have NO complaints with this kit! I think when youigher then you ned to work on the engine. GREAT KIT!!!
Old Nov 9, 2003
Drivetofast's Avatar
Supercharged k20a3
Drivetofast is an unknown quantity at this point
it's not the SF kit people have problems with, you take a risk by puting a turbo on an NA motor no matter what
