For SF turbo owners
Old Nov 4, 2003
aznrj's Avatar
aznrj is an unknown quantity at this point
Lightbulb For SF turbo owners
i'm almost close to ordering a turbo kit from SF. is there any real cons to the kit from installin it on a stock car w/ after-cat exhaust? what type of problems have you guys encountered through time? also the highest safe boost to run??
Old Nov 4, 2003
futurersxswap's Avatar
Passin' You On 19's.....!
futurersxswap is an unknown quantity at this point
this is the FIREST time i ever told someone this.,.. but SEARCH! dtock = fine.. max boost = 6-8psi depending on model, and 9-12psi if you get alcohol injection...
Old Nov 4, 2003
andyman97's Avatar
Turbo Guru
I blew my engine up. It's a great system, makes really good power. Just be careful. I wouldn't recommend going higher than 8 psi.
Old Nov 5, 2003
detoX's Avatar
detoX is an unknown quantity at this point
blew your engine? did you run a 9 psi or maybe higher? i thought that was the alcohol injection for..but still you blew your engine?
Old Nov 5, 2003
rscivic's Avatar
rscivic is an unknown quantity at this point
Andyman:I am running 8psi now. What happened w/ the blown up engine?
The kit is great, I put it on w/ an aftermarket exhaust. I took us about 15 hours on one weekend and tuning time after about 5 hours.
Let me know if you have any problems.....
Old Nov 5, 2003
andyman97's Avatar
Turbo Guru
I had nothing but problems after I put the turbo on. I had more downtime than I had to drive the car. It overheated a few times. I changed the headgasket a few times. I had excessive blow by and then blew a ring or broke a piston lan.
Old Nov 5, 2003
detoX's Avatar
another blown engine with an SF turbo kit..hmmm...
Old Nov 6, 2003
MadWheel's Avatar
Premium Boosted Member
Was it installed right? I'm running 4.5 psi, runs with 0 problems whatsoever. You think when I get my MBC and alcy I should keep it at 7-8 and not go to the 10psi they said I'd be able to run?
Old Nov 6, 2003
UnOrthodox9546's Avatar
UnOrthodox9546 is an unknown quantity at this point
I thought there was no tuning requored? What tuning did you do and is it necesary if i install it myself and w/ some friends?
Old Nov 6, 2003
not to down on ANYONE.. cause stuff happens.. but NOONE has actaully had a problem with the kit itself or the parts.. itss been ALL people messing up with things and doing something VERY worng... as with ANY mail order thing.. there's gonna be problems.. i drive my car hard as HELL.. no probs at aLL.. and imon 9psi DAILY... PLEA SE PLEASE PLEASE PLEASE stop hating on the SF kit.. itrs the best out there.. so more people have bought.. so more people have problems based soley on the numbers.... more possibilities = more problems.. if more people called SF as soon as they ha a slight problem, less people would have blown motors.. keep in mind we oinly have 1 dead motor.. and 1 other guy i can think of with probs.. and that was HUMAN ERROR.. NOT the kit..
Old Nov 7, 2003
tdiddy's Avatar
tdiddy is an unknown quantity at this point
You tell'm
Old Nov 7, 2003
fuchs's Avatar
fuchs is an unknown quantity at this point
Unhappy
I just wish my kit would get here so i could see what all the fuss is about.
HondaGuy7
Feb 22, 2016 01:00 PM
Sep 27, 2015 11:33 AM
ChrisHandHonda
26
Sep 25, 2015 11:28 PM
JMKendrick
Sep 16, 2015 06:17 PM
xorex83
Sep 8, 2015 08:07 PM
