Trubo tuning issues...need some help
Old Oct 29, 2003
RiceBuRNeR's Avatar
Turbo Member
I cant figure this one out. My new boost controller arived set at 5-6psi. The car felt like it was pulling harder than it ever did at 9psi w/ the turbo XS boostcontroller.
I set my new boost controller at 9 pounds and it seemed like I just couldnt deliver enough fuel, so I turned it back 5 psi and turned my fuel adj. back about 1.5%.
It hit 5-6 psi but felt like it was lagging out and even missing some top end power. So I turned the fuel up a little and went for another run, it pulled harder but only hit a max of 3 PSI. Any thoughts? or sujestions?
Old Oct 29, 2003
PlatCruiser's Avatar
PlatCruiser is an unknown quantity at this point
Get on the dyno with a wide band and stop messing around imp:
Old Oct 29, 2003
RiceBuRNeR's Avatar
Turbo Member
No dyno neer me (checked w/in 4 hour radius), cant afford wide band. And I had it working great untill just recently.
Old Oct 29, 2003
Catalyst's Avatar
Catalyst is just really niceCatalyst is just really niceCatalyst is just really niceCatalyst is just really nice
Here is a small tip... Always tune it extremely rich, and work from there. This should cut down some of the risks of tuning without a dyno.
Old Oct 29, 2003
RiceBuRNeR's Avatar
Turbo Member
But it seems like whenever I go rich I make less boost. Do you know why thats happening?
Old Oct 29, 2003
Catalyst's Avatar
Are you sure your boost controller is working properly?
Old Oct 29, 2003
RiceBuRNeR's Avatar
Turbo Member
Yea, this happens evrytime I screw w/ the fuel hough.
Old Oct 29, 2003
futurersxswap's Avatar
Passin' You On 19's.....!
futurersxswap is an unknown quantity at this point
man.... sounds like prob with boost controller... but also could be boost leak somwhere in vac lines... look around man...
Old Oct 29, 2003
RiceBuRNeR's Avatar
Turbo Member
Originally posted by NeonImpact
hey man, what about tempest racing??
they are in the waldorf area, but i dunno how far that is from you..
about 20 mins from me..
www.tempestracing.com
Thanks man, thats about 3 hours away. Yeah no boost leaks, this is wierd.
Old Oct 29, 2003
Boosted2k2's Avatar
Boosted2k2 should not be trustedBoosted2k2 should not be trusted
What kind of boost controller? And what type of wastegate?
UltraHDGames
Jun 8, 2016 05:16 PM
shadowfist
Oct 18, 2015 02:38 PM
beanhead
Sep 24, 2015 12:04 PM
Zedoc
Engine Swaps
Sep 12, 2015 04:27 PM
NaturalSelectio
Sep 6, 2015 06:59 PM
