For those with Alcy injection...UPDATED WITH LINK
Old Oct 17, 2003
MadWheel's Avatar
Premium Boosted Member
What type/brand alcohol did you guys buy? I was told I can use rubbing alcohol but what do you use?
*EDIT* Look at post 14.
POST 14
Old Oct 17, 2003
sexcivic2k1's Avatar
someone must know?
Old Oct 17, 2003
iamboo's Avatar
Retired - SoCal FI Mod
DO NOT USE RUBBING ALCOHOL!!!!
i used it for a long time it causes nothing but trouble.... the rubbing alcohol causes severe misfire at boost... i stalled on the freeway a couple times because of it.... you need something that's denatured like M1 methanol....
Rubbing alcohol has water mixed with the alcohol which in my opinion caused all the misfiring... trust me... just run pure methanol and you'll be fine...
Old Oct 17, 2003
futurersxswap's Avatar
Passin' You On 19's.....!
futurersxswap is an unknown quantity at this point
PUUUUUUUUUUURE methonal bro... NOTHING else... wont allow it.. and meth isnt that expensive.. like $3 a gallon.. you need 1 per week or so
Old Oct 17, 2003
i've heard distilled water will work too.?
Old Oct 17, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
Old Oct 17, 2003
wasn't sure..
Old Oct 17, 2003
MadWheel's Avatar
Where can I find pure methonal? I need it before I go racing at the track. Thanks
Old Oct 18, 2003
Catalyst's Avatar
Catalyst is just really niceCatalyst is just really niceCatalyst is just really niceCatalyst is just really nice
Many race shops will have it.
You can use water, but you will not be able to run as much boost. That is for people who just want to run about 8 psi and just want a little more power. The water does everything the Alcohol does, except raise the octane rating. That is what makes alcohol work soo well.
Old Oct 18, 2003
MadWheel's Avatar
I live in NH. There really isn't any race shops around here. Would large places like Walmart have it? What about Autozone or Pep Boys?
Old Oct 18, 2003
PdchasinR6's Avatar
PdchasinR6 is an unknown quantity at this point
i dont see why rubbing alcohol (Isopropyl Alcohol) would cause the car to stall...to be honest rubbing alcohol will raise your octane level slightly higher that methanol will when you have a 10% mixture with gasoline. in my friends supra we run Xylene in it to raise the octane level and his alky injection we run rubbing alcohol to get an extra octane boost
Old Oct 18, 2003
Stone's Avatar
Stone is an unknown quantity at this point
Yeah I also wuold like to know where you could get some methanol
I live in Houston.
I dont have or plan to get an alchohol setup, but would ust like to know anyways.
Old Oct 19, 2003
MadWheel's Avatar
anyone know?
Old Oct 19, 2003
MadWheel's Avatar
AHhah!
After almost 2 hours of searching I found the best deal I can get for people who need to have methanol shipped. New Hampshire doesn't have any places that sell it. I found a site online.
Click Here
This place ships 5 gallons of methanol for only $45.95. That should cover you for about a week according to consumptions that I've heard. I plan on buying this over the winter and stocking up for racing in the Spring. For this week, I'll buy some rubbing alcohol just to hold me over. I can run 10psi on alcohol right? - Its the SF kit obviously.
Old Oct 19, 2003
Catalyst's Avatar
I only went through about 1/2 gallon a week. When you first get your turbo on the car, you will probably go throug a gallon or so a week, but when you CALM DOWN and drive like a civilized person, it will last a long time!
Old Oct 19, 2003
Elite's Avatar
Elite is an unknown quantity at this point
GOD DAMN I WANT A TURBO!!!!! IMMA JUST GET A LOAN!!!!
Old Oct 19, 2003
Elite's Avatar
anyone willing to co-sign the apr will be cheaper
Old Oct 19, 2003
Elite's Avatar
btw will nitrous and alcohol injection kit be too much for the engine to handle I say around 50-75 shot?
Old Oct 19, 2003
boostin's Avatar
boostin is an unknown quantity at this point
I run isopropyl alcohol. First you can buy it in two different isopropyl percentages. You can get 75% or 93%(i think). Isoproyl has a higher octane level than methanol. Also you are SUPPOSED to add water. It should be around a 50-50 mixture. You should use distilled water when you mix it. I have a tank in my trunk that is about 2 gal. It cost me $5 to fill. I filled it once, that was about 2 months ago. I have been down the strip probably 15 times since, and I use it all the time! I haven't gone throug a gallon yet!!! I dont drive like crazy though. And my car has only ran better since I added the alcohol/water injection!! Most people actually run winshield wiper fluid that CONTAINS methanol. Dumb if you ask me!! You can actually run straight water for the same result but not as drastic. The alcohol raises the octane and keeps everything a little cooler. If you dont believe me on this check out aquamist's web site. They are the company that jackson racing gets their kits from. Hope this helps out.
www.aquamist.co.uk
Old Oct 19, 2003
i've seen that page somewhere, thanks for the link
Old Oct 19, 2003
MadWheel's Avatar
Isn't isopropyl alcohol the same as rubbing alcohol?
Old Oct 19, 2003
Elite's Avatar
i think so I just used a bottle rigth now.
Old Oct 19, 2003
Boosted2k2's Avatar
Boosted2k2 should not be trustedBoosted2k2 should not be trusted
ding ding.. you get a cookie!
Old Oct 19, 2003
C2i0v0i1C's Avatar
SuperMODrizd
www.aquamist.co.uk
pics of the ride?
Old Oct 19, 2003
boostin's Avatar
I dont have any pics! I dont have a digital camera! I will get some as soon as i can for you!
Old Oct 19, 2003
Havok2k1's Avatar
Wicked Pissah Admin
Doesn't this sound a little expensive for most people? $50 every month for methanol? Or every two months? I guess if you want to play, you have to pay....
Old Oct 19, 2003
Catalyst's Avatar
How much you use depends on how heacy your foot is. Theoretically, you can go forever without using any. All you have to do is not go over 6 psi, because at 6 psi, thats when the alcohol starts spraying.
Old Oct 19, 2003
C2i0v0i1C's Avatar
SuperMODrizd
and when u play big u pay big
Old Oct 19, 2003
MadWheel's Avatar
yeah and you win big and feel big haha. I'll try to get methanol but will prob end up with rubbing alcohol for this weekend, can i run 10psi on rubbing alcohol?
Old Oct 20, 2003
iamboo's Avatar
i don't understand why isopropyl alcohol doens't work well with my car.... i run straight methanol and it works sooo much better... no bogging in the high end, no misfiring or detonation.... i've had all these problems occur with isopropyl alcohol... this is very interesting to me...
