For those with Alcy injection...UPDATED WITH LINK
Old Oct 20, 2003
  #31
MadWheel's Avatar
Premium Boosted Member
so can i run 10psi on rubbing alcohol?
Old Oct 20, 2003
  #32
boostin's Avatar
boostin is an unknown quantity at this point
I dont think you understand madwheel. The kit is designed to use just water. Using just water you should be able to run about 10psi I would think. Isopropyl has a higher octane rating that methanol so i dont see how methanol could be better. I only run isopropyl! I have no problems whatsoever. I have run about 12psi with it and I had no problems then. But no one can tell you exactly what your motor will handle. I think that you can run 10 psi all day with isopropyl. I run around 9psi daily with isopropyl.
Old Oct 26, 2003
  #33
CivicMexicano's Avatar
El Pinche Turbo Mexicano
CivicMexicano is an unknown quantity at this point
the kit is not designed just to use wate, its a 50/50 mix so that the alcohol also raises th octane raiting in order to run more boost...
Old Oct 26, 2003
  #34
MadWheel's Avatar
tru that
Old Oct 26, 2003
  #35
and i'm pretty sure you can use rubbing alcohol to run 10 psi only one members has had prblems with it' and it might be cause he was using a 100% mix....
Old Oct 27, 2003
  #36
iamboo's Avatar
Retired - SoCal FI Mod
not so... i'm using 100% alcohol now and i'm not having any problems at all... the isopropyl alcohol was only 70% alcohol and 30% water....
Old Oct 27, 2003
  #37
sorry my mistake....
Old Oct 27, 2003
  #38
opto_isolator's Avatar
I wouldn't use 100% alcohol. According to Aquamist's web site:
"10. What is the maximum alcohol/ water ratio I should use?
No more than 50%, otherwise you will increase the cylinder temperature rather than reducing it. Beyond that ratio, onset of detonation is more likely. Methanol freezes at -96 deg. C, 50% mixture will stop the mixture from freezing at around -40 deg.C. "
This came from their FAQ's....
Old Oct 27, 2003
  #39
It also states this regarding methanol:
"9. Why is Methanol better?
Methanol itself has a octane number of 113. Not only does it improve your fuel quality, it will also give you a better intercooling effect in the inlet tract."
juror
Suspension DIY
Jul 30, 2019 03:28 AM
rovafa2002
Sep 28, 2015 06:57 PM
General DIY
Sep 25, 2015 08:02 PM
beanhead
Sep 24, 2015 12:04 PM
ZoSoIV
Sep 17, 2015 07:17 PM
